EcoStruxure process expert
AVEVA Plant SCADA Forum
A support forum for AVEVA Plant SCADA (formerly Citect SCADA). Share new and exciting product information, connect, learn, and collaborate with the ecosystem of Plant SCADA Users. AVEVA Plant SCADA a reliable, flexible and high-performance Supervisory Control and Data Acquisition software solution for industrial process customers. This forum is to connect, share, learn and collaborate new and exciting product information. Feel free to join and share to your Ecosystem of Plant SCADA Users.
  • Industrial Automation
  • AVEVA Plant SCADA Forum
  • EcoStruxure process expert
olivier_vallee
Commander olivier_vallee
34
Oncom
Commander Oncom
6
Kien_Mac
Lieutenant JG Kien_Mac Lieutenant JG
2
AVEVA
AVEVA™ Plant SCADA
EcoStruxure™ Process Expert
AVEVA Group PLC
AVEVA System Platform
Back to AVEVA Plant SCADA Forum
Salah_Mohamed
Ensign Salah_Mohamed Ensign
Ensign
Posted: ‎2023-07-17 10:39 AM
2213
What's the difference between AVEVA Plant SCADA and EcoStruxure process Expert ?
  • Communication Drivers
  • New Releases
  • Plant SCADA Anywhere
  • Reports
Replies 4
Sumanjith.an
Sumanjith.an Support
Support
Posted: ‎2023-07-17 11:59 PM
2153
AVEVA Plant SCADA is a Supervisory Control and Data Acquisition (SCADA) software solution for industrial process applications.
And the EcoStruxure Process Expert is a modern, distributed control system designed to reduce resources spent on engineering and commissioning. Designed especially for water, mining, cement, power generation, consumer packaged goods and chemical applications.
Salah_Mohamed
Ensign
Posted: ‎2023-07-19 01:20 AM
In response to Sumanjith.an
2112
but both are Wonderware based and has same ability and speed of polling tags right ?
Sumanjith.an
Support
Posted: ‎2023-07-19 04:40 AM
In response to Salah_Mohamed
Both are not Wonderware based. Looks like you are talking about the Aveva system platform, formally Wonderware.
EcoStruxure Process Expert is not a SCADA, it is a platform that helps the users to create the required tags to communicate control project with Aveva Plant SCADA as well as Aveva System Platform.
AntonioIacoviello
Crewman AntonioIacoviello Crewman
Crewman
Posted: ‎2023-08-25 06:31 AM
in other words, Plant SCADA doesn't have all the functionalities described by @Sumanjith.an but EPE uses (in a VM environment) PS to build some graphics and some SCADA functionalities.
You can achieve the same as EPE does by using Plant SCADA as well, but you will lose some tools and functionalities.
