Difference between Aveva Plant SCADA HMI and Aveva Plant SCADA Full Server
AVEVA Plant SCADA Forum
A support forum for AVEVA Plant SCADA (formerly Citect SCADA). Share new and exciting product information, connect, learn, and collaborate with the ecosystem of Plant SCADA Users. AVEVA Plant SCADA a reliable, flexible and high-performance Supervisory Control and Data Acquisition software solution for industrial process customers. This forum is to connect, share, learn and collaborate new and exciting product information. Feel free to join and share to your Ecosystem of Plant SCADA Users.
  • Industrial Automation
  • AVEVA Plant SCADA Forum
  • Difference between Aveva Plant SCADA HMI and Aveva Plant SCADA Full Server
olivier_vallee
Commander olivier_vallee
34
Oncom
Commander Oncom
6
Kien_Mac
Lieutenant JG Kien_Mac Lieutenant JG
2
AVEVA
AVEVA™ Plant SCADA
Back to AVEVA Plant SCADA Forum
sinced
Ensign sinced
Ensign
Posted: ‎2022-04-11 11:17 AM
5295
Good day,
Please what is the difference between Aveva Plant SCADA HMI and Aveva Plant SCADA Full Server ?
Is it possible to have a standalone connection between M251 and Aveva Plant SCDADA HMI 600 points using Modbus TCP ? Is an OPC Server required ?
  • Smart Design & Engineering
Stevey
Crewman Stevey Crewman
Crewman
Posted: ‎2022-04-12 02:33 AM
5268
Hi Sinced
AVEVA Plant Scada HMI provides functionality for Plant Scada running on a single PC.  AVEVA Plant Scada Full Server can be used in more advanced architectures such as Client / Server and Redundant configurations across multiple machines.
The Scada functionality is essentially the same for both.
M251 supports Modbus TCP so you could locate your PLC variables to Modbus addresses and read/write to them from AVEVA Plant Scada which comes with a Modbus TCP driver as standard (both HMI and Full Server options).
Alternatively you could use an additional OPC Server to communicate with the M251 without the need to locate variables in the PLC.  I think that there is an OPC Server included with EcoStruxure Machine Expert (M251 programming Software)
Hope that helps
Regards
Stevey
Stevey
Crewman
5269
Hi Sinced
Hope that helps
Regards
Stevey
sinced
Ensign sinced
Ensign
Posted: ‎2022-04-18 01:52 AM
In response to Stevey
Thank you for the clarification.
