SSH from Fedora 41 to AP9631 fails: ssh_dispatch_run_fatal: error in libcrypto
  • SSH from Fedora 41 to AP9631 fails: ssh_dispatch_run_fatal: error in libcrypto
aswen
aswen
Cadet
Posted: ‎2025-01-28 12:10 PM
2652
SSH to my AP9631 NMC fails with this error:
$ ssh -v apc-ups.my.net.work
OpenSSH_9.9p1, OpenSSL 3.2.2 4 Jun 2024
debug1: Reading configuration data /home/alex/.ssh/config
debug1: /home/alex/.ssh/config line 31: Applying options for apc-ups.my.net.work
debug1: /home/alex/.ssh/config line 108: Applying options for *.my.net.work
debug1: /home/alex/.ssh/config line 172: Applying options for *
debug1: Reading configuration data /etc/ssh/ssh_config
debug1: Reading configuration data /etc/ssh/ssh_config.d/20-systemd-ssh-proxy.conf
debug1: Reading configuration data /etc/ssh/ssh_config.d/30-libvirt-ssh-proxy.conf
debug1: Reading configuration data /etc/ssh/ssh_config.d/50-redhat.conf
debug1: Reading configuration data /etc/crypto-policies/back-ends/openssh.config
debug1: /etc/ssh/ssh_config line 57: Applying options for *
debug1: configuration requests final Match pass
debug1: re-parsing configuration
debug1: Connecting to apc-ups.my.net.work [172.17.255.240] port 22.
debug1: Connection established.
debug1: identity file /home/alex/.ssh/id_rsa type -1
debug1: Local version string SSH-2.0-OpenSSH_9.9
debug1: Remote protocol version 2.0, remote software version cryptlib
debug1: compat_banner: no match: cryptlib
debug1: Authenticating to apc-ups.my.net.work:22 as 'apc'
debug1: load_hostkeys: fopen /home/alex/.ssh/known_hosts2: No such file or directory
debug1: load_hostkeys: fopen /etc/ssh/ssh_known_hosts: No such file or directory
debug1: load_hostkeys: fopen /etc/ssh/ssh_known_hosts2: No such file or directory
debug1: SSH2_MSG_KEXINIT sent
debug1: SSH2_MSG_KEXINIT received
debug1: kex: algorithm: ecdh-sha2-nistp256
debug1: kex: host key algorithm: ssh-rsa
debug1: kex: server->client cipher: aes256-ctr MAC: hmac-sha2-256 compression: none
debug1: kex: client->server cipher: aes256-ctr MAC: hmac-sha2-256 compression: none
debug1: kex: ecdh-sha2-nistp256 need=32 dh_need=32
debug1: expecting SSH2_MSG_KEX_ECDH_REPLY
debug1: SSH2_MSG_KEX_ECDH_REPLY received
debug1: Server host key: ssh-rsa SHA256:5gSMQHqToW5REDACTEDt+vms
debug1: Host 'apc-ups.barchem.de-eekhoorn.eu' is known and matches the RSA host key.
debug1: Found key in /home/alex/.ssh/known_hosts:54
ssh_dispatch_run_fatal: Connection to 172.17.255.240 port 22: error in libcrypto
My SSH Config:
### APC UPS ###
host apc-ups.my.net.work apc-ups 172.17.255.240
Hostname apc-ups.my.net.work
user apc
HostKeyAlgorithms +ssh-rsa
PubkeyAcceptedAlgorithms +ssh-rsa
PreferredAuthentications keyboard-interactive,password
KexAlgorithms +diffie-hellman-group1-sha1
Ciphers aes256-ctr
MACs hmac-sha2-256
PasswordAuthentication yes
PubkeyAuthentication no
VerifyHostKeyDNS no
#### DEFAULTS ####
Host *
LogLevel QUIET
ForwardAgent no
SendEnv LANG LC_*
HashKnownHosts no
Port 22
Protocol 2
ServerAliveInterval 15
ServerAliveCountMax 5
PubkeyAuthentication yes
PasswordAuthentication no
ChallengeResponseAuthentication no
ForwardX11 no
ForwardX11Trusted no
HostKeyAlgorithms ssh-ed25519-cert-v01@openssh.com,ssh-rsa-cert-v01@openssh.com,ssh-ed25519,ssh-rsa
Ciphers chacha20-poly1305@openssh.com,aes256-gcm@openssh.com,aes128-gcm@openssh.com,aes256-ctr,aes192-ctr,aes128-ctr
MACs hmac-sha2-512-etm@openssh.com,hmac-sha2-256-etm@openssh.com,umac-128-etm@openssh.com,hmac-sha2-512,hmac-sha2-256,umac-128@openssh.com
KexAlgorithms curve25519-sha256@libssh.org,diffie-hellman-group-exchange-sha256
VerifyHostKeyDNS yes
Client
"Fedora Linux 41 (Workstation Edition)"
6.12.10-200.fc41.x86_64 #1 SMP PREEMPT_DYNAMIC Fri Jan 17 18:05:24 UTC 2025 x86_64 GNU/Linux
openssh.x86_64 9.9p1-1.fc41 updates
openssl.x86_64 1:3.2.2-11.fc41 updates
NMC
* Model: AP9631 hw revision 5
* Application module: v7.1.8
* AOS v7.1.8
* Boot monitor v1.0.9
I don't really know what's wrong?
  • ssh
KarimEissa
Commander KarimEissa Commander
Commander
Posted: ‎2025-02-17 06:41 AM
2573
If you are using RedHat Linux or related distros ,you may have issues connecting to NMC's via SSH
Redhat has implemented changes to their crypto policies which can cause the SSH connection to fail with the following error message:
"ssh_dispatch_run_fatal: Connection to xxx.xxx.xxx.xxx port xx: error in libcrypto"
you can view the current policies by running the following command: "update-crypto-policies --show"
If the return output is "DEFAULT", you will need to enable legacy options.
This is done by running "update-crypto-policies --set LEGACY" with elevated privileges.
Once done, you will need to restart the linux machine in order for the policy changes to become active.
Karim
Replies 4
KarimEissa
Commander
2574
Karim
aswen
aswen
Cadet
Posted: ‎2025-02-18 12:45 AM
In response to KarimEissa
Thanks @KarimEissa for showing me this work around. I'm using SSH to login to many systems and need to do that as secure as possible. Switching my entire SSH config back to LEGACY is, from that perspective, not the safest solution.
How can I configure the host entry of my APC card in `.ssh/config` so that I can login to the NMC without lowering the standards for all my connections? (I know that SSH tries to negotiate the securest option, but it's not without reason that some ciphers and kex algorithms are removed from DEFAULT).
KarimEissa
Commander
Posted: ‎2025-02-18 09:07 AM
You may need to refer to the below link for SSH connections to NMC
https://community.se.com/t5/APC-UPS-Data-Center-Enterprise/Scripting-SSH-connections-to-NMC-s-take-2...
 you may need to adjust the list of SSL/TLS ciphers in use for NMC web access on the NMC, to comply with local security policies, changes in browser compatibility, or to reflect ever-changing best practices.
Via the NMC command line:
Issue the “cipher” command to show the current enabled set, or “cipher help” for usage notes.
eg;
apc>cipher help
Usage: cipher --  Configuration Options
    Note: The minimal protocol setting is not considered when showing
           the available ciphers.
    cipher [-aes (enable | disable)] (AES)
           [-dh (enable | disable)] (DH)
           [-rsake (enable | disable)] (RSA Key Exchange)
           [-rsaau (enable | disable)] (RSA Authentication)
           [-sha1 (enable | disable)] (SHA)
           [-sha2 (enable | disable)] (SHA256)
           [-ecdhe (enable | disable)] (ECDHE)
Note:
Prior to 6.8.0, each option (eg -rc4) toggled the current state; these are now explicitly deterministic.
Reboot to commit changes.
Example:
List current settings, showing that all available are enabled (as default):
>cipher
E000: Success
Key Exchange Algorithms
        DH                   enabled
        RSA Key Exchange     enabled
Authentication Algorithms
(Warning: disabling the only algorithm in category
          will block all SSL/TLS sessions)
        RSA Authentication   enabled
Block Cipher Algorithms
        triple-DES           enabled
        RC4                  enabled
        AES                  enabled
MAC Algorithms
        MD5                  enabled
        SHA                  enabled
        SHA256               enabled
Disable RC4 cipher and RSA key-exchange:
>cipher -rc4 disable
E002: Success
>cipher -rsake disable
E002: Success
List new settings, confirming expected changes:
>cipher
E000: Success
        DH                   enabled
        RSA Key Exchange     disabled
        triple-DES           enabled
        RC4                  disabled
        AES                  enabled
MAC Algorithms
        MD5                  enabled
        SHA                  enabled
        SHA256               enabled
Using INI files (eg, for mass configuration):
[CryptographicAlgorithms]
;Warning: Changing these values can affect system access.
TripleDES=enabled
RC4=disabled
AES=enabled
DH=enabled
RSA_KE=disabled
RSA_Auth=enabled
MD5=enabled
SHA=enabled
SHA256=enabled
Using the web interface:
These settings are not yet exposed via the web UI.
Troubleshooting:
Be aware that disabling ciphers may affect browser compatibility; SSL/TLS will be unusable to the user unless their browser and the NMC have at least one cipher suite in common. Browser errors such as "ssl_error_no_cypher_overlap" or "err_ssl_version_or_cipher_mismatch" would indicate such an incompatibility.
Karim
Shaun
Commander Shaun Commander
Commander
Posted: ‎2025-02-19 05:28 AM . Last Modified: ‎2025-02-19 05:29 AM
Hi @aswen,
This can't really be solved in the ssh config - this is the operating principle for Red Hat's crypto policies.  Your ssh configuration is correct, but when it attempts to use a routine that's disallowed by the current policy, libcrypto throws an exception.
This means we can't solve this on a per-host basis, the system-wide crypto policy is the blocker.
The least invasive configuration I've found to work is
update-crypto-policies --set DEFAULT:SHA1
Instead of setting the whole policy to LEGACY, this will leave us on DEFAULT except with sha1 re-enabled so the group1-sha1 kex is no longer a policy violation.  It is still a step down from DEFAULT, however - the only real alternative I've found to that is to have an alternate toolchain in a container, so the containerized ssh isn't using the host's libcrypto.
