New network management card 3, cannot login via https
Send InviteCancel
Posted: 2023-02-0107:28 AM
Our APC Symmetra 40K had a network card go bad, which was replaced this week. I am trying to configure it now. I have https & port 443 enabled, but when I try to login via Chrome, I get the error below. I *can* open the URL on MS Edge, but my coworker gets this message using Chrome & Edge. Any suggestions on what I need to do to fix this?
Your connection is not private
Attackers might be trying to steal your information from<Ip address>(for example, passwords, messages, or credit cards).Learn more
NET::ERR_CERT_INVALID
<IP Address> normally uses encryption to protect your information. When Chrome tried to connect to <IP Address> this time, the website sent back unusual and incorrect credentials. This may happen when an attacker is trying to pretend to be <IP Address>, or a Wi-Fi sign-in screen has interrupted the connection. Your information is still secure because Chrome stopped the connection before any data was exchanged.
You cannot visit <IP Address> right now because the website sent scrambled credentials that Chrome cannot process. Network errors and attacks are usually temporary, so this page will probably work later.
