Send InviteCancel
Posted: 2025-03-2611:12 AM
Mass configuration for AP9641 using tftp
Hi all, i'm trying to deploy the config to our NMC 3 FW: 2.5.4.4 via DHCP / tftp. According to the NMC 3 User Guide from 03/2023 there is an option to upload the config.ini to the NMC via tftp. I've set up an DHCP server with ... option tftp-server-address [ip] option bootfile-name "config.ini" option 43 = 0x01 0x04 0x31 0x41 0x50 0x43
As far as i can tell the options are delivered to the card but it is not loading the config.
Hopesomeonecanpointmeintherightdirection Kind regards Jo
