How much power does the UPS SMT1500RMI1U consume when charging.
Send InviteCancel
Posted: ‎2025-04-2204:15 PM
I am sizing a distribution transformer in a machine that uses the UPS SMT1500RMI1U as back up for the PC.
The UPS is rated 1500VA / 1000W, I am wondering if this is the power that will consume when charging of it is only the rated power available for the UPS load side?
Looking at the product datasheet I found the following specification:
Battery Charge Power (Watts)
73 W rated
Can I take this value as the charging power consumption? The battery model on this UPS is APCRBC88
Posted: ‎2025-04-2304:54 AM
The system you indicated can support 1000 watts RMS continuous. The 73 watt charger value is the maximum output it can provide to recharge a fully depleted battery cartridge.
The power output varies based on SOC, Temperature, and battery condition.
The SMT1500 has an idle power consumption of approximately 25 ~ 32 watts depending upon configuration and if green mode is enabled / disabled.
