Battery lifetime exceeded.
  • Battery lifetime exceeded.
5060
142
Lesren
Lieutenant | EcoXpert Master Lesren Lieutenant | EcoXpert Master
Posted: ‎2024-03-20 11:00 PM
4174
Hi.
After replacing the battery in the SRT 2200, an accident appeared on the device screen, the battery needs to be replaced. The web interface also displays this error (in the attachment). Calibration was successful. The accident didn't go away.
Replies 8
Kirk
Posted: ‎2024-03-21 06:32 AM
4143
You just need to enter the new battery installation date as seen in your second photo. 👍
Lesren
Posted: ‎2024-03-21 08:07 PM
In response to Teken
The date was entered when the replacement, but the UPS does not accept it.
Lesren
Posted: ‎2024-03-22 02:37 AM
4097
When entering data through the device's display, the settings are not saved.
Kirk
Posted: ‎2024-03-22 05:14 AM
In response to Lesren
4089
Please do the same through the NMC Web Interface and report back the results. As a reminder insure the system clock (date & time) are correct and can reach an accurate NTP Server! ☝️
Lesren
Posted: ‎2024-03-22 06:11 AM
4087
The date and time are configured through the NTP server, today I changed the installation date both through the web interface and through the display, the error does not go away, the date of the next replacement does not change. Through the display, it does not save any settings. I will try to shut down the UPS completely.
Kirk
Posted: ‎2024-03-22 06:16 AM
4084
What date are you entering into the system? Based on your image it says 2022?!?
Lesren
Posted: ‎2024-03-24 10:19 PM
4029
Да, я ошибочно ввел 2022 год, вместо 2023 сохранилось изменение даты (через веб-интерфейс), через дисплей не сохраняется. Дата следующей замены не изменилась.
Kirk
Posted: ‎2024-04-01 01:02 PM
Just to be clear the battery cartridge was installed this year (2024) - correct?!? As your screen capture shows an input date of 2023? 🤔
In the interim I would complete a brain dead procedure in case the system is in some unknown state.
Brain Dead: Disconnect all loads, remove AC Mains, disconnect battery cartridge, press & hold the power button. You may hear a click and beep from the unit once complete.
Reconnect the entire system and power up.
Login to the NMC and change the battery installation date and report back the results. Insure the system clock is accurate and the unit reports NTP was successful.
