AB7920B cannot bootup
Send InviteCancel
Pay special attention to page 15 as it relates to the LED status and their meaning.
Ensure you have the supplied APC proprietary serial cable. As you’ll need to access the unit via the CLI using a terminal program like Putty.
All of the above is the most basic you need to have on hand and understand. If your network uses any kind of certificates, authentication, fixed IP Addressing etc.
You will definitely need to connect to the PDU directly with the serial cable with a laptop so configured to communicate with the target PDU.
