84579members
353849posts
Trend di citect error, muncul "Trend archive property mismatch"
PLC Club Indonesia
Wadah diskusi seputar PLC,HMI, SCADA dan semua hal seputar otomasi pada proses industri, baik mengenai hal teknis, informasi terbaru dan juga seputar bisnis. Forum ini terbuka unutuk semua system integrator industrial di Indonesia
Oncom
2
3211
Ada yang tau ini kenapa? Dan gimana cara mengatasinya?
Rifqi_Imanto
Lieutenant JG Lieutenant JG
3208
Re: Trend di citect error, muncul "Trend archive property mismatch"
Ini biasanya gara-gara ada ngerubah property terkait setting trend server atau trend tags nya. Atau ganti nama project.
Resolution:
Hapus semua trend data. Lokasinya menyesuaikan setting lokasi di trend tags masing-masing. Default nya ada di Folder "data" citect
2 Replies 2
Rifqi_Imanto
3209
Resolution:
Kris_Lian
Anyone Help me on my case citect scada 2018.
I want to input int data type on supergenies then give data to metadata genies and builder.
My project is to get data from button command to give 1-9 bit to enable open valve by supergenies.
I was try give instruction
On SG : ?int AVselect?
On genies : %AVselect%
Builder Variable : AV select to PLC1_avselect(tag variable int type)
But it still not works.
Need your support advice please. Thank you
