84248members
353348posts
Where can i find the on/off voltage range of the digital input signal on the ION7650?
Metering & Power Quality
Jeon
263
hi all,
Can you tell me the information about the range of on/off state for ion7650 as above?
thanks a lot.
Best regarlds
DanL
Commander Commander
Re: Where can i find the on/off voltage range of the digital input signal on the ION7650?
The ION7650 digital inputs have internal "self-excitation" and will register as "Closed" when an Sn (n=1 to 8 ) digital input is connected to Scom with a voltage between 0V (short) and 130VDC.
  • A wire with less than 10k Ohms (ideally less than 1 Ohm) across the terminals will register as CLOSED.
  • A connection with a (non-negative) voltage up to 130VDC applied (ideally less than 30VDC) will register as CLOSED.
  • A negative voltage exceeding -20V is applied (recommended practice is to provide an open circuit instead of a negative voltage) will register as OPEN.
  • A connection with more than 1Meg Ohms (ideally more than 10 Meg Ohm) across the terminals will register as OPEN.
2 Replies 2
Charles_Murison
Picard Picard
Picard
242
Hello @Jeon,
The screenshot you provided is likely from ION9000, PM800 or ION7400 meter. The ION7650 meters uses a completely different design. There are no ranges, there is open or there is close.
https://www.se.com/ww/en/download/document/70002-0247/, page 11. The digital inputs require Open/Close signal with or without external DC voltage.
Charles
DanL
Commander Commander
