84257members
353354posts
Structured Text SQL Query with Direct Variable filter
Hardin4019
Lieutenant
Lieutenant
1572
I'm trying to make life a little easier on myself. I have a Mimic with some fields to enter information about a meter template. In particular this meter template doesn't have its own Outstation/Scanner, (this template is for a second, third, or forth meter run). I want to fill in a field "ScannerParentGroupName" that is a String type Variable that I want to use to filter a query in my structured text program that I will setup to fill in the ScannerID field for the points in the template. I have structured text program below, but for some reason, the program upon execution will ask you what value should be assigned to "Scan" since it is a VAR_INPUT. Moving the Scan := ScannerParentGroupName; up before the query doesn't work, and changing the VAR_INPUT to VAR doesn't work. What am I missing?
Code;
TYPE
SCANNER : DATABASE_OBJECT(TfScanner)
FULLNAME: STRING;
END_DATABASE_OBJECT;
END_TYPE
PROGRAM TEST
VAR_INPUT
Scan:STRING;
END_VAR
VAR
NEWSTRING AT %M(.New String):STRING;
ScannerParentGroupName AT %I(.Scanner Parent Group Name):STRING;
END_VAR
VAR NOCACHE
Os AT %S(SELECT Id, ID AS SCANNNERID, FULLNAME FROM TfScanner WHERE FULLNAME LIKE ?) : RESULTSET OF SCANNER WITH_PARAMS Scan;
END_VAR
NEWSTRING := Os.Value.ID;
END_PROGRAM
geoffpatton
Re: Structured Text SQL Query with Direct Variable filter
I have a ST program that on interval executes just fine, but if I right click on it and select execute then it prompts me for the ParentFolderInput. It was written in version 2010 R1.1
I was annoyed by it and thought it should not do that, but at the time I was trying to get the project finished and since it worked on a Interval as I needed it I just moved on and never inquired why it does this.
If you use a method button to execute it, you can set it to a null '' (single quote, single quote) for its initial value.
Here is what  I did for reference.
PROGRAM MyTextProgram
METHOD
Exec AT %M(.Trigger ST_EA.Execute):STRING;
END_METHOD
VAR
ParentFolder AT %M(..FullName) : STRING;
END_VAR
VAR_INPUT
ParentFolderInput : STRING;
END_VAR
ParentFolderInput := CONCAT(ParentFolder, '.BI.%');
Exec(ParentFolderInput);
END_PROGRAM
3 Replies 3
geoffpatton
METHOD
END_METHOD
VAR
END_VAR
VAR_INPUT
END_VAR
END_PROGRAM
BevanWeiss
Spock
Spock
1564
When calling ST SQL with parameters, I normally end up having two logic routines.
The first just setups what the 'inputs' to the query are going to be, and then calls Execute on the second logic routine passing in the inputs which are then VAR_INPUTs on the second logic routine.
This is mostly related to the way that the 'sequence' of ST execution occurs.
The SQL Logic is part of the 'Input' scan, which means that it occurs at the same time as the VAR variables are initialised.. which is why the SQL Params can't be VAR variables, they MUST be VAR_INPUT variables, which are available to the ST logic PRIOR to the ST executing.
Hardin4019
Lieutenant
Lieutenant
Thanks for taking the time to reply and giving me the direction I needed guys.
