84262members
353369posts
Standby GEOSCADA server shut down suddenly
BGedco2022
352
Hello Everyone,
We've client with hot-stand by GEO SCADA partner where the stand by server found shut down suddenly.
What could causes such behavior?
Thanks in advance
5 Replies 5
sbeadle
Janeway Janeway
Janeway
340
Re: Standby GEOSCADA server shut down suddenly
Many reasons - disk space being one.
Check your server log files. Contact support line for help.
BGedco2022
256
Thanks @sbeadle but the disk space is not an issue.
We checked the log files, watchdog  exception was found...
*** Exception Database watchdog timed out. at 00007FF85D989319 occurred **
How can we detect the cause/solve it?
AndrewScott
247
That message indicates that the database watchdog has detected that the server has stalled and so has shut it down.
See System Administration > Server Administration > Logging and Monitoring > Configure the Database Watc...
To investigate what caused the server to stall you need to examine the DB logs in the minutes prior to the watchdog being triggered (default 4 minutes), or contact customer support and supply the DB log files and the dump file created by the watchdog.
Andrew Scott, Lead Engineer, AVEVA
BGedco2022
245
what are the prospects could cause that?
AndrewScott
There are many possible reasons, for example oversized historic granules in the historian or poorly designed/optimised SQL queries.
