84255members
353353posts
Filtering out Alarm List using SCRIPT in ClearSCADA
mhayat
782
Hi All,
Can anybody help me with this:
I need to apply filtering on Alarm List using some kind of script. What i am trying to achieve here, i have a filter script which i use to filter out some wells on a normal list but i am looking to add a functionality which will look at the Alarm list at the same time and filtered out the alarms only associated with the filtered wells.
In short how can i edit the filter functionality using script in Alarm list.
BevanWeiss
Spock
Spock
775
Re: Filtering out Alarm List using SCRIPT in ClearSCADA
It's possible to change the Animation properties on mimic objects during runtime.
It can get a little tricky however...
Essentially there is a bit of a hierarchy: Mimic -> Layers -> Items -> Properties (inc animations)
So if you know the layer name, and the alarm list name, you should be able to access it via
Mimic.Layers("LAYER_NAME").Items("ITEM_NAME").Filter = "*"
And then the Filter property should align with what is required.  I don't remember the exact setup for the Alarm List filters, I can't recall if it's actually a collection, in which case you'd need to do things like call .Add(), .Clear() those kind of Collection methods on it, or whether it is just a delimited string.  You could MsgBox the current value of it and get some info on this.
2 Replies 2
BevanWeiss
Spock
Spock
776
mhayat
Thank you it worked for me.
