84598members
353864posts
Tags in SQL statements?
AVEVA Plant SCADA Forum
A support forum for AVEVA Plant SCADA (formerly Citect SCADA). Share new and exciting product information, connect, learn, and collaborate with the ecosystem of Plant SCADA Users. AVEVA Plant SCADA a reliable, flexible and high-performance Supervisory Control and Data Acquisition software solution for industrial process customers. This forum is to connect, share, learn and collaborate new and exciting product information. Feel free to join and share to your Ecosystem of Plant SCADA Users.
jthyge
1828
Hello
How is it possible to use tags in SQL statements in Machine SCADA Expert?
If I e.g. want to change the database the select is made in.
SELECT * FROM [TAG].trend001
Best regards
Jesper
Paul_Derbyshire
Ensign Ensign
1
1805
Re: Tags in SQL statements?
Hell Jesper,
You can use {} to enclose tags in a DBExecute script command.
For example:
SELECT * FROM {MyTag}.trend001
However, you want to change the database?
You can change the database/ERP reference in the DB Execute.
$DBExecute($MyDBConnection, "SELECT * FROM trend001")
Where $MyDBConnection is a string which contains the of the Database/ERP connection name that you created.
@jthyge wrote:
Hello
Best regards
Jesper
Paul Derbyshire
Senior Product Application Expert | Sales Enablement | HMI Line of Business, Digital Factory | Industrial Automation Business | Schneider Electric
4 Replies 4
Rodrigo_Garcia
Hello @TomDroll , Could you support on this?
Rodrigo G.
Industrial Automation Community manager
Paul_Derbyshire
Ensign Ensign
1
1806
Hell Jesper,
For example:
@jthyge wrote:
Hello
Best regards
Jesper
Paul Derbyshire
TomDroll
Lt. Commander Lt. Commander
HI,
Yes it is possible to add tags to your SQL query. there are 3 options available.
Option 1:VB Script or Function where you can use VB Variables to build the query and then the $DBExecute function. something like this:
Dim SQL
SQL = "SELECT FROM Table WHERE Column = " & $TagName
$DBExecute("Connection",SQL)
Option 2: You can also use the script database command $DBSelect command with the syntax below.
DBSelect("DB1","Table1","Array1,Array2","Column1,Column2","","")
Option 3: You can use the database worksheets in the Tasks->Database/ERP folder,  the condition field would be your select where from would be.
Hopefully this helps!
Tom Droll
jthyge
Thanks Paul  and Tom
This was just what I was looking for.
