84257members
353354posts
Custom widget help
AVEVA Plant SCADA Forum
A support forum for AVEVA Plant SCADA (formerly Citect SCADA). Share new and exciting product information, connect, learn, and collaborate with the ecosystem of Plant SCADA Users. AVEVA Plant SCADA a reliable, flexible and high-performance Supervisory Control and Data Acquisition software solution for industrial process customers. This forum is to connect, share, learn and collaborate new and exciting product information. Feel free to join and share to your Ecosystem of Plant SCADA Users.
energima
1878
Custom widget help
I need help with the function in the .JS file to make my widget works. Do you have any documents or information or how cwidget function works?
Thanks in advance
8 Replies 8
Paul_Derbyshire
Ensign Ensign
1851
Re: Custom widget help
Hello @energima
Which software and software version # are you using with widgets?
I look forward to hearing from you.
Paul Derbyshire
Senior Product Application Expert | Sales Enablement | HMI Line of Business, Digital Factory | Industrial Automation Business | Schneider Electric
energima
1846
Hi thx for replying,
Machine Scada expert last version. 2020
jthyge
1683
Hi @energima
Did you solve your problem with Custom Widget in Machine SCADA Expert?
I am following the documentation from help:
Screens and Graphics > Custom Widget >Edit the web files for a custom widget
But I can not read the data from the property in the custom_widget.js
energima
1671
Yeah after several trial an error I find my problem.
Maybe you can send me your file and I can checking it.
@jthyge
jthyge
1661
Hi @energima
That would be very nice.
The custom_widget.js file?
How can I send it to you. The direct message does not seem to work.
energima
1653
Yes with your index file.
kcaron@energima.ca
energima
And you .wjson file
omelak
Hi @energima
Widget is a sort of SDK or client of your service that other site owners embed on their websites. At the minimum they consist of JavaScript code and, if there is a UI part, HTML with CSS. Different widgets do different things, but the common for them is that you hand over some small piece of code to be embedded on foreign site.
