84623members
353938posts
APC ES550 incorrect estimate shutdown time and battery charge amount after replace battery
Musmarc
602
Hi all,
recently during a power outage I saw that my APC ES550 was giving constant beeps so I supposed the battery was exausted and I bought a new one.
After replacement and recharging the new battery for 12h, I noticed that the Powerchute software was erroneously indicating 3 minutes of available power backup time.
I tried to disconnect the power and let the device run until shutdown, but with a laptop, modem and hub connected it lasted for about 1 hour.
Then I found istructions in the forum on how to reset this estimation, running a load of at least 30% of the maximum load to the APC and let it run until it is shut down.
Using a 250W device, it consumed all the battery charge in about 10-12 minutes (I suppose it's correct).
After another full recharge, the estimation still sits on 10 minutes and the APC starts crazy beeping after only 30 seconds of power outage, even if it lasts for 1 hour with the attached devices.
There is another procedure/software to reset it?
8 Replies 8
JonPro
Lt. Commander Lt. Commander
464
Re: APC ES550 incorrect estimate shutdown time and battery charge amount after replace battery
Hi @Musmarc,
From the PowerChute software that you have mentioned, can you update the battery replacement date?
Please see if you have Monitor System > Run Self-Test > Replace Battery Date on your end.
JonPro
Secure Power Team
Musmarc
457
Hi @JonPro ,
I didn't find the option in the installed software.
I'm using the latest version of Powerchute Personal Edition (v.3.1).
There is a way to enable this option?
Marco
JonPro
453
Hi @Musmarc,
PCPE reads the data/information from the UPS, for your UPS this feature is not available.  Can you provide the model of your UPS?
JonPro
Secure Power Team
Musmarc
451
Hi @JonPro,
the model is APC ES550, this one for the Italy market (https://www.apc.com/it/it/product/BE550-IT/apc-backups-es-550-va-230-v-italiano/ discontinued).
Marco
@Musmarc
The option is not available for all Back-UPS. The option appears if the the UPS has been designed with the feature. Since the option does not appear that indicates the UPS does not offer the feature.
JonPro
432
@Musmarc
Just like what BillP said, the firmware of your UPS does not support this feature.  Aside from doing a manual runtime calibration wherein you are going to connect at least 25% of the load and let the UPS run on battery until it turns off, I recommend running a self-test on the UPS and doing a complete logic reset.
See How to Brain Dead a Back-UPS unit. (Full UPS Logic Reset)
JonPro
Secure Power Team
Roadwarrior
i got the same issue with mine and no succes APC should provide a solution for this situation
helenamic7
Thanks for help, I am also new here and learning a lot from this community, glad to be here.
