84829members
354283posts
management card software
juanrico_apc
444
This was originally posted on APC forums on 9/24/2008
Hello.
I've got three APC Smart UPS's (1500, 2200, and 3000) protecting three Dell Poweredge 2950's. I understand that I will need a network management card in each UPS for optimum control. My latest UPS came with a network management card in it, although I'm not sure which one. I think that I would buy two identical cards, unless someone tells me that I should vary the cards. Anyway, I would like to control UPS from a workstation inside my firewall and also remotely over my VPN so that I can initiate graceful shutdowns on all hardware when necessary. What software do I need to accomplish this?
EZ_Button_apc
Re: management card software
This was originally posted on APC forums on 9/26/2008
When you install the software, it'll ask you to enter then IP's of the management cards.
3 Replies 3
juanrico_apc
This was originally posted on APC forums on 9/25/2008
Does the software seek out the network mamanement cards, or do I have to enter the IP numbers manually? Thanks, Erasmus, for the previous answer.
Sisko
Sisko
You will need the aforementioned network management cards for your UPS units (AP9617 is the base unit and is fully capable of network shutdown), as well as the PowerChute Network Shutdown (most recent version is v2.2.3) software installed on each of the servers in order to shut them down.
UPS' that come with NMC's are usually the Smart-UPS RT line, modular line, or higher-level UPS systems.
Message was edited by: Erasmus
EZ_Button_apc
