84628members
353951posts
how can i wake up any pcs with SmartUPS 3000
245
This question was originally posted by Guilherme on APC forums on 5/2/2011
I got nobreak SmartUPS 3000 and i trying configure it to shutdown and wake up any pcs. but i want to know if there are a software can do it?
Re: how can i wake up any pcs with SmartUPS 3000
This reply was originally posted by Angela on APC forums on 5/2/2011
do you use a network management card or via a serial connection?
if using a network management card, you will want to look at powerchute network shutdown at the following link (Filter by Software Downloads - Powerchute Network Shutdown) -> http://www.apc.com/tools/download/index.cfm
if using a serial connection, look at powerchute business edition (Filter by Software Downloads - Powerchute Business Edition) -> http://www.apc.com/tools/download/index.cfm
2 Replies 2
This reply was originally posted by Guilherme on APC forums on 7/12/2011
hello, i has using the PowerChute Business Edition, but i can't shutdown the machines, exemple:
i'm try using the following script
@START "" "C:\Program Files (x86)\APC\PowerChute Business Edition\agent\cmdfiles\myShut.bat"
Inside the file myshut.bat have this script: shutdown /s /m \\myPC /d 1:1 /f /t 60
i did try without the tag @START only shutdown /s /m \\myPC /d 1:1 /f /t 60, but with the application PowerChute B. doesn't execute the .bat .
I have 3 server on this no-break and i didn't turn off him.
Someone can help?
