84245members
353345posts
disable popups
actek_apc
200
disable popups
This was originally posted on APC forums on 8/11/2011
I have searched for an answer here but found nothing. I am running PCPE 3.0 and want to disable the popup notifications that happen every time the UPS switches in and out. We have a lot of noise on this AC feed and even at the lowest settings the UPS kicks in many times per hour. Can I turn off those messages that pop up off the lower right toolbar?
R2_apc
Re: disable popups
This was originally posted on APC forums on 8/30/2011
Hi actek, there is way to mute the alarms on the ups itself (so it will not make a beeping noise) however I believe in the cause of a transfer to battery a pop up notification will still come up letting you know the unit has changed state. Hope this helps.
1 Reply 1
R2_apc
Re: disable popups
