84816members
354269posts
SU3000RMXL3U Battery rplacement question
aisterab_apc
480
This was originally posted on APC forums on 1/31/2011
Went to replace batteries on a SU3000RMXL3U. Batteries were pulled from metal cartridge RBC27 and sent to recycling center. I need the wiring config in cartidge to plug the replacement batteries. Looks like 2/Red 2/Blck from plug, and several double ended blk connects. Looked all over website for information with no avail. Any help would be appreciated.
Re: SU3000RMXL3U Battery rplacement question
This reply was originally posted by Angela on APC forums on 1/31/2011
i think what JonPro was saying was that APC intends that you buy a genuine replacement RBC27 where we provide all of the cables, etc already pre-configured. APC does not support using third party batteries and APC cannot provide a wiring diagram to you. someone else might have one and you could utilize it at your own risk.
7 Replies 7
aisterab_apc
This was originally posted on APC forums on 2/1/2011
I see, and thanks for the advice,
Amar
Javik_apc
Who dissembled the battery pack? You? If so, take a picture next time before touching anything.
I just recently tore apart and discarded the cells from a 3000XL3U.
In my battery pack, the 8 batteries were two series strings in parallel.
Red Plug wire, Cell, Jumper, Cell, Fuse, Cell, Jumper, Cell, Black Plug wire
So, you should have 4 loose jumpers, and 2 loose fuses, and the 4 plug wires.
If not, then ask someone else for help.
(I do not represent APC, and I am just some random person on teh webz. Proceed at your own risk.)
blac11_apc
This was originally posted on APC forums on 2/4/2011
If you know the charging voltage of the unit then it will give you an idea on how to connect it, it is usually series-parallel connection. If the charging voltage is 25vdc, then batteries connected should have a reading of 24vdc to 25vdc.
hotmanali_apc
This was originally posted on APC forums on 2/8/2011
Hope this help... this is a pic of my battery module with the cover off.
This reply was originally posted by Jonathan on APC forums on 1/31/2011
If you have purchased an APC RBC27 battery it should be configured already and is placed on the metal tray.
aisterab_apc
I said I purchased the batteries for the RBC27 which is 8 12Volt batteries. I am reusing the cables and the casing. Is there documentation anywhere showing the wiring diagram?
