  • Get started
Brand Logo
  • Get started
  • Community Home
    • By Topic
    • By Topic
      EcoStruxure Building
      • Field Devices Forum
      EcoStruxure Power & Grid
      • Gateways and Energy Servers
      EcoStruxure IT
      • EcoStruxure IT forum
      • EcoStruxure IT™ Advisor CFD
      Remote Operations
      • Remote Operations Forum
      Industrial Automation
      • AVEVA Plant SCADA Forum
      • CPG Expert Forum DACH
      • Machine Automation Forum
      • Modicon PAC Forum
      • PLC Club Indonesia
      Schneider Electric Wiser
      Power Distribution IEC
      • Specifiers Club ZA Forum
      • Електропроектанти България
      Power Distribution NEMA
      Power Distribution Software
      • LayoutFAST User Group Forum
      Light and Room Control
      • SpaceLogic C-Bus Forum
      Solutions for your Business
      Support
    • Geo SCADA Knowledge Base
    • Digital E-books
    • Success Stories Corner
    • All Events
    • Innovation Talks
    • Innovation Summit
    • Let's Exchange Series
    • Partner Success
    • Process Automation Talks
    • Technology Partners
    • EcoStruxure Building
      Remote Operations
    • By Topic
    • By Topic
      • Backstage Access Resources
      EcoStruxure IT
      Remote Operations
      • Remote Operations Blog
      • Industrie du Futur France
      • Industry 4.0 Blog
      • NEMA Power Foundations Blog
      • KNX Blog
      • Digital E-books
  • companyImpact
SNMP v3 SETUP
  • Communities
  • Re: SNMP v3 SETUP
  • Subscribe to RSS Feed
5026
195
Sisko Erasmus_apc
111
TheNotoriousKMP_apc
Sisko TheNotoriousKMP_apc
108
Posted: ‎2021-06-30 05:45 AM
2196
SNMP v3 SETUP
This question was originally posted by Paul on APC forums on 4/20/2008
Has anyone got snmp v3 working on their pdu?
I have the following settings:
1. User Name: power
2. Authentication phrase : powerapc
3. Encryption phrase: powerapc
4. Access Type: Auth/NoPriv
Access is enabled for v3
Then using a call like:
snmpwalk -v 3 -u power -l authNoPriv -a MD5 -A powerapc -c public 156.241.33.110 -m "./powernet367.mib" PowerNet-MIB::apc
produces:
snmpwalk: Authentication failure (incorrect password, community or key)
I've set it up correctly and to me it looks like it should work. Has anyone got v3 snmp running ? I'm using
Rack PDU APP v3.5.6
Network Management Card AOS v3.5.7
Kind Regards
Paul
Message was edited by: moetman
TheNotoriousKMP_apc
Sisko
Posted: ‎2021-06-30 05:46 AM
This was originally posted on APC forums on 4/24/2008
Paul,
The one thing we were discussing and which I'm still unclear of, is that you were using the Public community string name in the original setup, but yet your Config.ini file also has it as private.
So now I'm at a point where I'm sort of confused as to where the problem lies.
We know we solved the problem with the Auth. phrase, but what's left other than the community string?
Replies 6
This reply was originally posted by Paul on APC forums on 4/21/2008
Yea that's set to 'Enabled' as well - still getting Authentication problems.
Janeway
This was originally posted on APC forums on 4/21/2008
One little gotcha I've run into is that not only does access need to be enabled for SNMPv3 but also for the user profile in the "access control" section. It defaults to disabled.
TheNotoriousKMP_apc
Sisko
This was originally posted on APC forums on 4/22/2008
Paul,
I received some information from a fellow moderator who has more in-depth SNMP knowledge than I possess...
Can you post your config.ini here?
Have you upgraded to version 3.5.8 on the PDU FW?
Have you upgraded to version 3.9.1 on the MIB (This I assume you have since I provided that link for another issue earlier)?
What NMS are you using?
Where are you inputting the authentication? We tried to replice with "powerapc" as the authentication phrase, except it requires the phrase to be 13 characters.
Is it possible for you to post your .ini file so that we can take a look at it, possibly upload it to one of our PDU's running the same FW and try the same thing you're trying by duplicating your v3 settings?
I broke it down like this:
snmpwalk -v 3
-u power Username
-l authNoPriv I don't know what this is*
-a MD5 Authentication Type
-A powerapc Auth Phrase (Too Short)
-c public 156.241.33.110 Community String (You're using the SNMP V1 Comm. String)
TheNotoriousKMP_apc
Sisko
This was originally posted on APC forums on 4/23/2008
Paul,
In the interest of the size, can you just edit your last post, and just attach your config.ini to the post? It's easier for me to download/view that way.
You stated changing the length of the Auth phrase helped. Just so I'm clear, what problem beyond that are you now facing?
This reply was originally posted by Paul on APC forums on 4/24/2008
No Problems - attached the config.ini.
Thanks and Best Regards
TheNotoriousKMP_apc
Sisko
Paul,
Additional options
Already have an account?Login
