  • Get started
Brand Logo
  • Get started
  • Community Home
    • By Topic
    • By Topic
      EcoStruxure Building
      • Field Devices Forum
      EcoStruxure Power & Grid
      • Gateways and Energy Servers
      EcoStruxure IT
      • EcoStruxure IT forum
      • EcoStruxure IT™ Advisor CFD
      Remote Operations
      • Remote Operations Forum
      Industrial Automation
      • AVEVA Plant SCADA Forum
      • CPG Expert Forum DACH
      • Machine Automation Forum
      • Modicon PAC Forum
      • PLC Club Indonesia
      Schneider Electric Wiser
      Power Distribution IEC
      • Specifiers Club ZA Forum
      • Електропроектанти България
      Power Distribution NEMA
      Power Distribution Software
      • LayoutFAST User Group Forum
      Light and Room Control
      • SpaceLogic C-Bus Forum
      Solutions for your Business
      Support
    • Geo SCADA Knowledge Base
    • Digital E-books
    • Success Stories Corner
    • All Events
    • Innovation Talks
    • Innovation Summit
    • Let's Exchange Series
    • Partner Success
    • Process Automation Talks
    • Technology Partners
    • EcoStruxure Building
      Remote Operations
    • By Topic
    • By Topic
      • Backstage Access Resources
      EcoStruxure IT
      Remote Operations
      • Remote Operations Blog
      • Industrie du Futur France
      • Industry 4.0 Blog
      • NEMA Power Foundations Blog
      • KNX Blog
      • Digital E-books
  • companyImpact
SC-1500s last only three years?
  • Communities
  • Re: SC-1500s last only three years?
  • Subscribe to RSS Feed
5026
195
Sisko Erasmus_apc
111
TheNotoriousKMP_apc
Sisko TheNotoriousKMP_apc
108
RogerStrong_apc
Crewman RogerStrong_apc
Posted: ‎2021-06-29 12:18 AM
463
Share
This was originally posted on APC forums on 4/28/2010
We have two SC-1500s, installed at the same time three or four years ago.
The "replace battery" warning activated on one of them. We replaced the battery, and we get a "battery disconnected" warning.
Before we could solve that problem, the "replace battery" warning activated on the other UPS. This time we had our supplier install the new battery. Again, now we get a "battery disconnected" warning.
We've tried letting them charge - with the alarms sounding - for several days.
The supplier is telling us that both UPSs are broken, and they want to sell us new ones.
Is this normal? One battery, three years, and then you must replace the UPS?
  • apc
  • bac
  • battery
  • dead
  • disconnected
  • replace
  • sc1500
  • smartups
Share
Posted: ‎2021-06-29 12:19 AM
Share
This reply was originally posted by Laurie on APC forums on 4/29/2010
Those units should work fine. The problem is the power that the UPS outputs when on battery - the SC models output a step-approximated sine wave and the SMT units produce a pure sine wave. So as long as they are sized properly, they should work just fine.
Share
Replies 6
UPS_Tech_apc
Ensign UPS_Tech_apc
Share
This was originally posted on APC forums on 4/29/2010
got it in a nutshell my friend. SC1500i will not run ML350 prioliant servers..
will kill them. APC do not recommend running the particular model on the SC1500I ever, also a knowledge base article floating around.
I suspect you would have had load issues, perhaps when bouncing back from automated batt tests or mains fail.
Recommend upgrading to SUA1500I.
Share
UPS_Tech_apc
Ensign UPS_Tech_apc
Share
may i ask what server or equipment type is powered off the UPS ?
Maybe Proliant ML350 range ?
Share
RogerStrong_apc
Share
Both UPSs powered a Proliant ML350 each. (One with HP branding and the other older one with Compaq branding.)
I've unplugged both UPS's, and left them plugged in with and without a load for days, both turned on and off.
Share
Share
Did you try a pull plug test at all to see if the unit actually functions when it's supposed to be running on battery?
Share
RogerStrong_apc
Share
Thanks!
I couldn't find a knowledge base article on the APC site, but I found several forum threads on the HP site once I knew what to look for.
The vendor wants us to replace them with the SMT750, SMT1000 or SMT1500. I can't find any information to tell me whether this will give us the same problem as the SC models.
Any comments?
Thanks again.
- Roger Strong
Share
Share
Share
Additional options
Already have an account?Login
