84576members
353847posts
Powerchute Network Shutdown 4.4.3 Virtual Appliance - Refusing connection to web interface
dessyboy
I have just installed PCNS 4.4.3 Virtual Appliance on a VMWare ESXi 6.0 host. I configured the initial settings via the console and restarted.  I can ping the PCNS VA IP address but cannot connect to the web interface https://Server IP:6547 to continue configuration.
I am on the same subnet with no firewall in between and when using windows network troubleshooter it reported that the server is running but refused my connection.
I had the same issue with PCNS 4.4.2 and upgraded to 4.4.3 hoping that it was just an issue with the version.
I also have other servers running PCNS 4.4.1 without issue.
Any help would be appreciated.
743
Re: Powerchute Network Shutdown 4.4.3 Virtual Appliance - Refusing connection to web interface
3 Replies 3
MattGH
hello,
Also having the same issues. After install Powerchute Network Shutdown 4.4.3 Virtual Appliance. The server boots and I see the ip of the server with port 6547 to continue the setup. But I am getting an error. Website can not be contacted.
Can someone please assist with this issue.
744
@dessyboy
You need to set the web UI username and password. See Schneider Electric FAQ PowerChute Network Shutdown version 4.4.2 & 4.4.3 web page is not accessible after installing onto s...
dessyboy
Thanks, this worked. The change in default behavior had me perplexed.
Much appreciated!
