84384members
353570posts
PCNS Virtual Applicance, VMware Tools update not working
ChrisHaag_apc
529
This was originally posted on APC forums on 12/29/2016
After updating to vSphere ESXi 6.5 I tried to update the VMware Tools to 10.1.0 (version supplied with ESXi 6.5), which did not work
The automatic VMware Tools update started from the vSphere Web Client, as instructed on http://www.apc.com/us/en/faqs/FA176573/, reported that the file /usr/lib/vmware/isoimages/linuxPreGlibc25.iso does not exist.
A manual update using a downloaded (full) VMware Tools ISO did not work either. The message is "RPC greeting failed: Host software version may not be compatible with the Upgrader"
We have installed the PCNS Virtual Appliance recently under ESXi 6 and the VMware Tools update was no problem at all.
There are a few changes in ESXi 6.5 concerning CentOS, we could not find something about CentOS 5, which is used by the applicance. For CentOS 6 and above VMware advises to check the VM's OS settings if VMware Tools cannot be installed. There is nothing said about CentOS 5 and also the applicance is configured as "CentOS 4/5 64 Bit" (setting not changed by us).
Any idea how we can get this VMware Tools version installed?
ChrisHaag_apc
Re: PCNS Virtual Applicance, VMware Tools update not working
This was originally posted on APC forums on 1/2/2017
The problem is that ESXi 6.5 for some reason does not identify the OS of the virtual appliance correctly. linuxPreGlibc25.iso is not contained in the VMware Tools 10.1.0, as "Pre glibc 2.5" is a part of the legacy bundle, which is contained in the VMware Tools 10.0.12. But the virtual appliance has glibc version 2.5 and VMware Tools 10.1.0 would be the right version.
A manual installation worked - after unpacking the .tar.gz file:
1) Add a CD/DVD drive
2) Execute
mkdir /mnt/dvd
mount -t iso9660 /dev/hda /mnt/dvd
mkdir /root/vmware-tmp
tar -xzf VMwareTools-10.1.0-4449150.tar.gz -C /root/vmware-tmp/
cd /root/vmware-tmp/vmware-tools-distrib/
./vmware-install.pl
3) Go through settings
If using Veeam or similar, set the option "vmsync" to yes, all other can be on defaults
4) Clean up
rm -rf /root/vmware-tmp
umount /mnt/dvd
5) Guest hardware version can be safely upgraded to ESXi 6.5 = hardware version 13
6) All is green in VMware Update Manager now
3 Replies 3
ChrisHaag_apc
2) Execute
mkdir /mnt/dvd
./vmware-install.pl
4) Clean up
umount /mnt/dvd
ChrisHaag_apc
Btw. support cyle of CentOS 5 ends March 2017...
This reply was originally posted by Stefan on APC forums on 2/17/2017
There is no need to download and the unpack the .tar.gz file.
The VMware Tools 10.1.0 ISO image is available in vmimages/tools-isoimages/linux.iso when you select "Datastore ISO file" in the VM settings.
Anyway, thanks for the hint. That helped.
