  • Get started
Brand Logo
  • Get started
  • Community Home
    • By Topic
    • By Topic
      EcoStruxure Building
      • Field Devices Forum
      EcoStruxure Power & Grid
      • Gateways and Energy Servers
      • Protection & Control
      EcoStruxure IT
      • EcoStruxure IT forum
      • EcoStruxure IT™ Advisor CFD
      Remote Operations
      • Remote Operations Forum
      Industrial Automation
      • AVEVA Plant SCADA Forum
      • CPG Expert Forum DACH
      • Machine Automation Forum
      • Modicon PAC Forum
      • PLC Club Indonesia
      Schneider Electric Wiser
      Power Distribution IEC
      • Specifiers Club ZA Forum
      • Електропроектанти България
      Power Distribution NEMA
      Power Distribution Software
      • LayoutFAST User Group Forum
      Light and Room Control
      • SpaceLogic C-Bus Forum
      Solutions for your Business
      Support
    • Geo SCADA Knowledge Base
    • Digital E-books
    • Success Stories Corner
    • All Events
    • Innovation Talks
    • Innovation Summit
    • Let's Exchange Series
    • Partner Success
    • Process Automation Talks
    • Technology Partners
    • EcoStruxure Building
      Remote Operations
    • By Topic
    • By Topic
      • Backstage Access Resources
      EcoStruxure IT
      Remote Operations
      • Remote Operations Blog
      • Industrie du Futur France
      • Industry 4.0 Blog
      • NEMA Power Foundations Blog
      • KNX Blog
      • Digital E-books
  • companyImpact
Need a UPS to run a Nitto VP0940 vacuum pump
  • Communities
  • Need a UPS to run a Nitto VP0940 vacuum pump
  • Subscribe to RSS Feed
5027
195
Sisko Erasmus_apc
111
TheNotoriousKMP_apc
Sisko TheNotoriousKMP_apc
108
product field
Uninterruptible Power Supply (UPS)
mercury762
mercury762
Posted: ‎2022-07-26 01:12 PM . Last Modified: ‎2022-07-26 01:25 PM
1
400
The Nitto vacuum pump is 115VAC / 60Hz, 95 watt. It has a linear reciprocating piston. See spec: http://www.nitto-kohki.eu/en/products-en/pumps-a-compressors/ac-pumps/item/vp-0940.html
See the mechanism of free piston driven pump video: http://www.nitto-kohki.eu/en/video-en/pumps-a-air-compressors-videos.html
The APC UPS initially used to power the pump is the BX1000M.  Unfortunately this UPS failed to run the pump properly, it made noises and ran for a few minutes at half the flow rate.  I need a correctly sized UPS with the correct topology that will properly run the pump at full volume rate of 40 L/min, for at least 15 minutes.
Suggested replacement: BR1500MS2.  Can someone confirm that this UPS will run the pump correctly?
Hg
  • UPS for pump
Reply 1
JonPro
Commander JonPro Commander
Posted: ‎2022-08-28 11:59 PM
Hi @mercury762
Thank you for reaching out to the SE Community, my name is Jon and I will assist you with this query.  Apologies for the late revert, our Back-UPSs are meant to be used for an IT type of load. If you are planning to use an APC UPS to support the vacuum pump, I highly suggest that you reach out to the manufacturer of the pump to see if they have a list of recommended UPS that they have tested and are known to work.
Alternately we would recommend you gather the following specifications for your load:
  • Typical steady state draw
  • Maximum in-rush current
  • Maximum in-rush duration
  • Make and Model of all equipment that will be attached to the UPS
More information can be gathered from the articles provided below:
  • Can I use my Smart-UPS with non IT Loads?
  • he use of non computer type loads with a UPS, specific to Back-UPS, Smart-UPS SC
Additional options
