Why is it so difficult to get a UPS and a couple servers to work together?
We have a Smart-UPS (SRT 10000) with web-gui and Ethernet connected to the rack's main switch.
We have a couple servers with Ubuntu in the rack
The UPS is sending status packages, which are visible on the net, according to the format MASTATUS<body>....</body> every 20 seconds or so
What we want: if the battery goes down under 20% or if it is 10% left on the time we want the servers to shutdown gracefully.
This simple task seems to be impossible to do.
aopcupsd:
No, not working because the UPS seems to have changed the protocol to MASTATUS<body>....</body> which apcupsd can not handle correctly.
Powerchute:
No, it is only rpm packages (that is for red hat or SuSe)
Convert rpm into .deb? Well almost, because some shebang missing for !/bin/bash, there are errors about [[ statements in shell files etc.
Force convert it into .deb, do the installation and ignoring the warnings about [[
Will it work??? Of course not, when setting up powerchute (which of course is not named powerchute anymore but pcbeagent instead .....) the pcbeagent can only handle usb/serial cables during the setup.
NUT:
Have not even tried, when both apcupsd and Schneiders own software (powerchute/pcbeagent) fail this simple use case I do not even want to test,
It astonish me that that these things do not work out of the box or in a very simple way.
Schneider change the broadcast format so apcupsd no longer work, why ?
Schnedier make the software Powerchute which it is not, it is actually called pcbeagent, why ?
Why can not pcbeagent handle an Ethernet connection to the UPS during setup, why does it insist on usb/serial?
95% of the use cases of UPS's are very very very simple
Main power loss -> switch to battery
Before running out of battery -> graceful shutdown.
