84780members
354227posts
Gutor NMC
K-Dog_apc
701
Gutor NMC
This was originally posted on APC forums on 5/23/2007
Do the Gutor boxes use the same NMC as the other 3 phase products? Are all newer units capable of having a NMC installed into an existing slot? Do the older units that can be upgraded using a Silcon Triple chassis use the same cable from the triple chassis to the unit? The attached doc pointed me in the right direction but left a few questions unanswered.
thanx
Looks like I posted this in the wrong forum. I will repost in UPS and Data Center Management Software
Apologies
set:noobmode=0
Message was edited by: K-Dog
Tags (2)
K-Dog_apc
Gutor NMC
thanx
Apologies
set:noobmode=0
4 Replies 4
K-Dog_apc
Re: Gutor NMC
This was originally posted on APC forums on 5/25/2007
@ EZ-Button,
Let me know if these forums provide a way to send you a private message or e-mail you the serial numbers. Do you think this means that this reply is incorrect?
"The Gutor units use the same NMC as the APC 3-Phase units. There is a slot in the Gutor UPS, and the option for the Silcon Triple Chassis, as seen in the pdf you attached, can also be used with older Gutor systems. They will use the same firmware as the Silcon products."
This was from a cross posting in the "UPS & Data Center Management Software" forum. Also, does it mean the pdf attached to my first post is obsolete? I appreciate your support, we have been around the block on this one a few times.
thanx
K-Dog
EZ_Button_apc
Re: Gutor NMC
You can send a PM using the small "Envelope" icon in the top right. (near logout)
I called our Gutor tech to check on your questions. He wanted me to get the serial numbers to take a look at your system specs. I'm going to PM you some information. It may be easiest for you to contact him.
Message was edited by: EZ Button
K-Dog_apc
Re: Gutor NMC
This was originally posted on APC forums on 6/2/2007
Spoke to Gutor guru Charles Sims about this: the units in question are not equiped with a comm board (A076). They need a comm board, power supply to the board and a value changed in a stack. If the units are ordered with the board it can be retrofitted much easier with the methods outlined in the PDF attached to my first post.
K-Dog_apc
Gutor NMC
thanx
Apologies
set:noobmode=0
