84865members
354357posts
Console Port Server AP9302
Tomehb_apc
683
This was originally posted on APC forums on 8/6/2008
Hi Guys,
Just trying to configure a APC Console Port Server Model: AP3902.
I have connected a cable from a port (port 16) Too a Cisco 3600 Series Router.
When i attempt to connect to this router over the web interface or via ssh, all i dont get any output other than the following:
Welcome to Console Port Server C2Serial-APC-LHR port S014
C2Serial-APC-LHR login: root
Password: ***
The port Mode is in Console Raw, i have also tried others. Any ideas whats wrong? Or what i should try next, as i'm completely lost..
Tom
EZ_Button_apc
Re: Console Port Server AP9302
This was originally posted on APC forums on 8/12/2008
Here's a link to the document with all the adapters on it.
http://www.apcmedia.com/salestools/ASTE-6Z5QFE_R0_EN.pdf
To connect to a server's serial port, the db9 female - rj45 crossover adapter should work
6 Replies 6
EZ_Button_apc
This was originally posted on APC forums on 8/7/2008
Right, sounds like it's just the cabling issue. Unfortunately I can't give out the pinouts for that adapter, but you can certainly purchase it off the site.
Tomehb_apc
Anyone?
EZ_Button_apc
What exactly is this cable you are running from the CPS to the router?
Tomehb_apc
I have tried CrossOver/Straight Through/Roll over.....
I believe that I'm using an incorrect cable? As i found http://www.apcc.com/resource/include/techspec_index.cfm?base_sku=AP9315
Wondering if if anyone knows the pin configuration, so i can create a direct cat5 cable that goes from the console port too the APC without this adaptor.
Tom
Tomehb_apc
This was originally posted on APC forums on 8/8/2008
Thankyou, i'm going to order a few. I have a another question for you as there are so many adaptors.. Which Adaptor would i need to connect the Ap9302 to a Console port on a dell server..
Tom
EZ_Button_apc
