82523members
350129posts
Backup-UPS reporting 360 + minutes of battery time
188
This question was originally posted by Chris on APC forums on 1/23/2017
I have 3 Backup UPS systems reporting 360+ minutes of battery time. These have one regular tower and maybe a monitor. The box on the 550G said 43 minutes.
Anyone had a similar issue? a solution ?
Tags (2)
Re: Backup-UPS reporting 360 + minutes of battery time
This reply was originally posted by Chris on APC forums on 1/23/2017
Hi , thanks !!!! I have a PC/ monitor and small thermal printer on a 550, and a PC and 8 port switch on a 700
3 Replies 3
This reply was originally posted by Joe on APC forums on 1/23/2017
Sounds like your load is exceptionally low.  I wouldn't worry about it.  I am not sure about this particular system, but you may be able to do a run-time calibration test to check it out.
This reply was originally posted by Allen on APC forums on 1/23/2017
Hello Chris,
Good day to you. Joe is correct, the runtime of the UPS showing in powerchute might be inaccurate due to low load. At least 30% load should give you a much better runtime. May I know how much load is connected to the UPS?
