  • Get started
Brand Logo
  • Get started
  • Community Home
    • By Topic
    • By Topic
      EcoStruxure Building
      • Field Devices Forum
      EcoStruxure Power & Grid
      • Gateways and Energy Servers
      EcoStruxure IT
      • EcoStruxure IT forum
      • EcoStruxure IT™ Advisor CFD
      Remote Operations
      • Remote Operations Forum
      Industrial Automation
      • AVEVA Plant SCADA Forum
      • CPG Expert Forum DACH
      • Machine Automation Forum
      • Modicon PAC Forum
      • PLC Club Indonesia
      Schneider Electric Wiser
      Power Distribution IEC
      • Specifiers Club ZA Forum
      • Електропроектанти България
      Power Distribution NEMA
      Power Distribution Software
      • LayoutFAST User Group Forum
      Light and Room Control
      • SpaceLogic C-Bus Forum
      Solutions for your Business
      Support
    • Geo SCADA Knowledge Base
    • Digital E-books
    • Success Stories Corner
    • All Events
    • Innovation Talks
    • Innovation Summit
    • Let's Exchange Series
    • Partner Success
    • Process Automation Talks
    • Technology Partners
    • EcoStruxure Building
      Remote Operations
    • By Topic
    • By Topic
      • Backstage Access Resources
      EcoStruxure IT
      Remote Operations
      • Remote Operations Blog
      • Industrie du Futur France
      • Industry 4.0 Blog
      • NEMA Power Foundations Blog
      • KNX Blog
      • Digital E-books
  • companyImpact
APC SUA3000RM2U dead...?
  • Communities
  • Re: APC SUA3000RM2U dead...?
  • Subscribe to RSS Feed
5026
195
Sisko Erasmus_apc
111
TheNotoriousKMP_apc
Sisko TheNotoriousKMP_apc
108
glashoppah_apc
Ensign glashoppah_apc
Posted: ‎2021-06-29 08:53 AM
507
Share
This was originally posted on APC forums on 11/6/2014
Dear Forum,
I have an APC SUA3000RM2U, which is obviously older, and has been sitting on a shelf for a few years but was pulled from a working environment.   Upon applying power to the device it exhibits absolutely no reaction whatsoever - not a single light comes on, no clicks or sounds, nothing - it's like I've plugged a rock into the power outlet.  I've checked everything I can think of, pressed all the buttons, flipped the breaker on the back, etc. to no avail.  I've also let it sit on power for 24 hours.
Should this device exhibit *some* reaction to being powered?  I don't want to buy a battery pack for it until I'm sure that will fix the problem I'm perceiving.  And if I'm missing something simple, like a fuse I didn't notice, please let me know.
Thanks in advance for any help,
J.
  • 3000
  • dead
  • fault
  • ups
Share
Share
This reply was originally posted by Angela on APC forums on 11/7/2014
Typically, SUA units do not require the battery to turn on. Though, if there is no DC voltage present anywhere in the system, you may need batteries to jump start it.
Was the battery in this system stored connected or disconnected? Can you measure the voltage on the existing battery pack?
Share
Replies 7
Share
Share
glashoppah_apc
Share
This was originally posted on APC forums on 11/7/2014
It was stored connected and I'm certain it is completely drained.
Share
Share
This reply was originally posted by Angela on APC forums on 11/10/2014
From my experience, I do think it is worth a try to "jumpstart" it with new batteries, preferably if you're able to return the batteries if the UPS does happen to be the issue. I can't be sure which it is since the batteries are likely completely shot due to being stored connected and not periodically recharged.
Share
glashoppah_apc
Share
This was originally posted on APC forums on 11/11/2014
I may try to jury-rig a 48v source and jump-start it with that first...  at $260+, the battery pack is a big risk.
Share
glashoppah_apc
Share
OK - it worked.  I stacked 5 9v batteries and used a pair of test leads to energize the input connector from the battery pack.  Ping, on it came.  Thank you very much - it's dinging "Replace Battery" even with the old pack connected, so I'm going to order a new battery pack.
Thanks again!
Share
glashoppah_apc
Share
This was originally posted on APC forums on 11/12/2014
Final note - new battery pack received and installed, everything working perfectly.  Thanks again.  smile
Share
Share
This reply was originally posted by Angela on APC forums on 11/13/2014
Glad to hear. Thanks for the follow up!
Share
Additional options
Already have an account?Login
