84375members
353559posts
APC 3000 UPS, configuration shutdown NA?
Lorensen_apc
408
This was originally posted on APC forums on 10/26/2009
Hello
I have some problems with a APC 3000 UPS, that is acting wierd in the web-interface > UPS > configuration > shutdown.
The dropdowns which i can choose from(Low Battery Duration, Shutdown Delay, Minimum Battery Capacity and Return Delay), are all marked as NA, and i cannot pick other values as normal, do anybody know the solution to this problem?
Martin
Message was edited by: Lorensen
seoerming1_apc
Griffey Shoes
This was originally posted on APC forums on 3/23/2011
"That just tells you Syracuse wasn't that Griffey Shoes good," Barkley retorted. There will probably be people Air Jordan Heels who agree with Barkley that only eight Big East teams belonged in the NCAA tournament Ken Griffey Shoes as a result of the conference's awful showing, but the truth is the league simply performed well below Air Max 24 7 expectations in single-elimination format. Based on their season-long body of work, it would have been very difficult to justify leaving Nike Air Yeezy out Connecticut, Villanova or Marquette, the teams that finished ninth, 10th and 11th in the Big East regular-season standings. Even Nike Dunk Heels though he had the more logical argument, Pitino didn't exactly help himself when he looked straight into the camera and guaranteed "Notre Dame will not lose" Sunday night against Florida State. The lesson here: Never pin your TV credibility to Notre Dame in the NCAA tournament and never argue with Barkley even when you're right.
8 Replies 8
Lorensen_apc
Re: APC 3000 UPS, configuration shutdown NA?
This was originally posted on APC forums on 10/27/2009
It's a: Smart-UPS RT 3000XL
I'm using a single network card, and there's no serial or USB cable in the UPS.
APP name and version: sumx, v3.5.5
AOS name and version: aos, v3.5.5
This reply was originally posted by Angela on APC forums on 10/26/2009
we'd also need to know the exact model of the UPS from the white sticker on the UPS if possible.
Sisko
Sisko
Can you get the firmware information on the network card from the Administration -> General subtab and give us the (or a screenshot):
APP name and version (should be a three or four character name and version number)
AOS name and version (should be aos and a version number)
Are you using just this single network card, or do you have any extra accessory single/triple chassis hooked up to the UPS? Is there a serial or USB cable plugged into the UPS? If so, are you using PowerChute Business Edition on an attached server? What is the model and serial # of the network card installed in the UPS?
Janeway
Janeway
This was originally posted on APC forums on 10/29/2009
ipickedawinna, are you saying that the difference is that one is UPSLink and the other is Microlink? In that case, an easy way to tell on the NMC web interface is whether the UPS page names start with "up", ie upshome.htm (upslink UPSes) or starts with a "ul", ie ulhome.htm (microlink UPSes).
Lorensen_apc
It is kinda difficult for me to find out, because the UPS is placed into a Windmill about 4000 Miles away.
This reply was originally posted by Angela on APC forums on 10/30/2009
yes, thats good to know! thanks voidstar.
Lorensen, can you paste to us the hyperlink address (removing your IP) of the UPS tab for example?
beekerc_apc
Re: APC 2200 UPS, configuration shutdown NA?
This was originally posted on APC forums on 3/1/2011
I'm having a similar problem with my UPS
it's a SUA2200RM2U with an AP9606 Web/SNMP interface card
Firmware string is as follows.
American Power Conversion Web/SNMP Management Card AOS v3.2.6.b
(c) Copyright 2000 All Rights Reserved Smart-UPS & Matrix-UPS APP v3.2.6.a
can anyone help me with this unit?
seoerming1_apc
Griffey Shoes
