  • Get started
Brand Logo
  • Get started
  • Community Home
    • By Topic
    • By Topic
      EcoStruxure Building
      • Field Devices Forum
      EcoStruxure Power & Grid
      • Gateways and Energy Servers
      • Protection & Control
      APC UPS, Critical Power, Cooling and Racks
      EcoStruxure IT
      • EcoStruxure IT forum
      • EcoStruxure IT™ Advisor CFD
      Remote Operations
      • Remote Operations Forum
      Industrial Automation
      • Alliance System Integrators Forum
      • AVEVA Plant SCADA Forum
      • CPG Expert Forum DACH
      • EcoStruxure Automation Expert / IEC 61499 Forum
      • Fabrika ve Makina Otomasyonu Çözümleri
      • Harmony Control Customization Forum
      • Industrial Edge Computing Forum
      • Korea Industrial Automation Forum
      • Machine Automation Forum
      • Modicon PAC Forum
      • PLC Club Indonesia
      Schneider Electric Wiser
      Power Distribution IEC
      • Eldistribution & Fastighetsautomation
      • Elektrik Tasarım Dağıtım ve Uygulama Çözümleri
      • Paneelbouw & Energie Distributie
      • Power Distribution and Digital
      • Solutions for Motor Management
      • Specifiers Club ZA Forum
      • Електропроектанти България
      Power Distribution NEMA
      • Power Monitoring and Energy Automation NAM
      Power Distribution Software
      • EcoStruxure Power Design Forum
      • LayoutFAST User Group Forum
      Energy & Sustainability Services
      • Green Building Scoring and Certification Forum
      Light and Room Control
      • SpaceLogic C-Bus Forum
      Solutions for your Business
      • Solutions for your Business Forum
      Support
    • Remote Operations Devices Knowledge Base
    • Geo SCADA Knowledge Base
    • Industrial Automation How-to videos
    • Digital E-books
    • Success Stories Corner
    • All Events
    • Innovation Talks
    • Innovation Summit
    • Let's Exchange Series
    • Partner Success
    • Process Automation Talks
    • Technology Partners
    • EcoStruxure Building
      • EcoStruxure Building Advisor Ideas
      Remote Operations
      • EcoStruxure Geo SCADA Expert Ideas
      • Remote Operations Devices Ideas
      • Modicon Ideas & new features
    • By Topic
    • By Topic
      • Backstage Access Resources
      EcoStruxure IT
      Remote Operations
      • Remote Operations Blog
      • Industrie du Futur France
      • Industry 4.0 Blog
      • NEMA Power Foundations Blog
      • Active Energy Management Blog
      • KNX Blog
      • Digital E-books
  • companyImpact
Power Quality Meter Selection
This forum is specific to consulting engineers in South Africa where technical, commercial & legislative queries, comments, potential pitfalls and best practices can be shared.
  • Communities
  • Power Distribution IEC
  • Power Quality Meter Selection
  • Subscribe to RSS Feed
Send a co-worker an invite to the Exchange portal.Just enter their email address and we?ll connect them to register. After joining, they will belong to the same company.
PowerLogic ION9000
EcoStruxure™ Power Monitoring Expert
Back to Specifiers Club ZA Forum
Theren
Ensign Theren Ensign
Ensign
Posted: ‎2022-04-22 07:38 AM
To understand what type of power quality equipment to use to correct or suppress the issue. It is crucial to run simulations or perform a physical measure to have a better understanding.
It is essential to select the correct power meters to measure certain disturbances. There are different disturbances that one might focus on when choosing a power meter to do the job. Disturbances include voltage sag or swell, voltage flicker, harmonics, transients, power factor, etc.
Selecting the correct meter for the above disturbance is important, this can help identify the issues that can cause further damage on site. Most entry range power meters in the Schneider Electric meters can provide typical measurements, i.e., voltage, current, power, energy, power factor, total harmonic distortion, etc. To get individual harmonics, one needs to select the meter that can measure those parameters (from PM2000 and above). More advanced meters (such as the PM8000 & ION9000) can do waveform capture. Depending on what one wants to measure, the PM8000 can capture voltage sag & swell waveforms. Whereas the ION9000 has a faster sample rate (1024 samples in a cycle) that allows this meter to capture transients as well. Having these advanced meters, one can always program the meter (via ION Technology) to capture specific data that is needed even if the meter is not recording by default.
It is recommended to have meters with onboard memory to log the data even if the meter loses communication with the software. The size of the memory is important, depending on the application. If an application requires the meter to log all the data because there is no software, it’s obvious to get a larger memory meter or a separate data logger. On the other hand, if a software collects the data, it is not necessary to have such a larger onboard memory. A few megabytes are sufficient to log a few months of energy data. The type of data that needs to be logged on the meter is a factor to consider, typical voltage and current logs at 15-minute intervals do not require a lot of storage. However, if waveform capture is required or an intense amount of data points are to be logged, then larger memory is recommended.
After installing the correct meter, the data that is logged can be analysed to better understand how one can improve the power quality on the site.
Advanced Metering
ION Technology
  • Products
  • Advanced Power Meter
  • energy management
  • power quality
Replies 0
Additional options
You do not have permission to remove this product association.
You can subscribe to this forum after you log in or create your free account.
Terms & Conditions Privacy Notice Change your Cookie Settings © 2023 Schneider Electric, Inc
