  • Get started
Brand Logo
  • Get started
  • Community Home
    • By Topic
    • By Topic
      EcoStruxure Building
      • Field Devices Forum
      EcoStruxure Power & Grid
      • Gateways and Energy Servers
      APC UPS, Critical Power, Cooling and Racks
      EcoStruxure IT
      • EcoStruxure IT forum
      • EcoStruxure IT™ Advisor CFD
      Remote Operations
      • Remote Operations Forum
      Industrial Automation
      • Alliance System Integrators Forum
      • AVEVA Plant SCADA Forum
      • CPG Expert Forum DACH
      • EcoStruxure Automation Expert / IEC 61499 Forum
      • Fabrika ve Makina Otomasyonu Çözümleri
      • Harmony Control Customization Forum
      • Industrial Edge Computing Forum
      • Korea Industrial Automation Forum
      • Machine Automation Forum
      • Modicon PAC Forum
      • PLC Club Indonesia
      Schneider Electric Wiser
      Power Distribution IEC
      • Eldistribution & Fastighetsautomation
      • Elektrik Tasarım Dağıtım ve Uygulama Çözümleri
      • Paneelbouw & Energie Distributie
      • Power Distribution and Digital
      • Solutions for Motor Management
      • Specifiers Club ZA Forum
      • Електропроектанти България
      Power Distribution NEMA
      • Power Monitoring and Energy Automation NAM
      Power Distribution Software
      • EcoStruxure Power Design Forum
      • LayoutFAST User Group Forum
      Energy & Sustainability Services
      • Green Building Scoring and Certification Forum
      Light and Room Control
      • SpaceLogic C-Bus Forum
      Solutions for your Business
      • Solutions for your Business Forum
      Support
    • Remote Operations Devices Knowledge Base
    • Geo SCADA Knowledge Base
    • Industrial Automation How-to videos
    • Digital E-books
    • Success Stories Corner
    • All Events
    • Innovation Talks
    • Innovation Summit
    • Let's Exchange Series
    • Partner Success
    • Process Automation Talks
    • Technology Partners
    • EcoStruxure Building
      • EcoStruxure Building Advisor Ideas
      Remote Operations
      • EcoStruxure Geo SCADA Expert Ideas
      • Remote Operations Devices Ideas
      • Modicon Ideas & new features
    • By Topic
    • By Topic
      • Backstage Access Resources
      EcoStruxure IT
      Remote Operations
      • Remote Operations Blog
      • Industrie du Futur France
      • Industry 4.0 Blog
      • NEMA Power Foundations Blog
      • Active Energy Management Blog
      • KNX Blog
      • Digital E-books
  • companyImpact
How to select a VSD
This forum is specific to consulting engineers in South Africa where technical, commercial & legislative queries, comments, potential pitfalls and best practices can be shared.
  • Communities
  • Power Distribution IEC
  • How to select a VSD
  • Subscribe to RSS Feed
Send a co-worker an invite to the Exchange portal.Just enter their email address and we?ll connect them to register. After joining, they will belong to the same company.
Altivar Process (Low Voltage)
Back to Specifiers Club ZA Forum
Bhekumuzi_Hlebeya
Crewman Bhekumuzi_Hlebeya Crewman
Crewman
Posted: ‎2022-10-06 11:55 PM
1
977
How to select a VSD
This material aims as a guide to give an indication of how to select Variable Speed Drives (VSDs) from the Schneider Electric catalogue. This may not be your last point of guide, but it should give an idea of where to start.
VSDs are frequency-varying systems that are used in the power electronics space as motor starters. There are different functions that these machines can be used for, even the type of industry they serve. VSDs were first developed in the late 1950s when there was a growing need to conserve energy and use it efficiently. The technology gained popularity when improvements and technological advances were introduced, since the first units were very bulky and expensive [1]. Today they can be seen in most infrastructures, from pump applications, HVAC applications, conveyer applications and many other related controls.
For this article, only the Low Voltage (LV) VSD ranges will be discussed. There are two main sub-categories that we use to distinguish our main Altivar (ATV) offers. ATV900  and ATV600 , the control that sets the two units apart is based in their application. The built-in functions within the drive make it redundant to select the drive without drilling into the built-in functions inside the drive. For demanding applications such as hoisting, lifts, braking and other high torque controls, we recommend the ATV900. The ATV600 is more suitable for the pump, water, and wastewater applications. Figure 1 details the built-in functions for the two drives.
Figure 1: Built-in functions for ATV drivesFigure 1: Built-in functions for ATV drives
The drives have dual rating setting, Normal Duty (ND) and Heavy Duty (HD), to handle overloading capabilities. For a drive rated 120%, this drive can deliver 20% overload past nominal. For motor applications with high starting current, the drive can be overloaded by 150%(HD) for the first cycles, once the motor reaches synchronous speed, the drive overload capability can be changed to ND. The important part to note is the current limitation when the drive is loaded at HD; therefore derating must be taken into consideration when making a decision.
Both units can be wall mounted, floor standing systems and modular drives LV for cabinet integration. Floor standing systems can be categorized into three designs, Customized To Order (CTO), Engineered To Order (ETO) and Design To Order (DTO). CTO are standard cubicles with standard options such as push buttons. ETO are standard cubicles with customer-specific options such as painting and additional standard options that can be found in CTO designs. DTO are cubicles with specific designs with specific options. All of our VSD products are also green premium label  certified.
Reference material
[1] D. Roethemeye and D. Yankaskas, "EVOLUTION OF MOTOR AND VARIABLE FREQUENCY DRIVE," in ACEE, St. Louis,Missouri, 1995.
  • Energy Management
  • Products
BJacqz
Lt. Commander BJacqz Lt. Commander
Lt. Commander
Posted: ‎2022-10-11 07:05 AM
In addition, do not hesitate to use our EcoStruxure motor control configurator (https://www.se.com/myschneider/configurators/mcc) and as well our Altivar Process Configurator (https://configurator-at.schneider-electric.com/Altivar_Process_Configurator/).
Both could be helpful, the first one for complete solution determination and second for drive determination.
Bruno Jacqz, Drives training leader
Additional options
You do not have permission to remove this product association.
You can subscribe to this forum after you log in or create your free account.
Terms & Conditions Privacy Notice Change your Cookie Settings © 2023 Schneider Electric, Inc
