The Server details are saying that I have the correct elements, and I know my base URL is the correct path for where the variables are, but my program is not pulling any data points I have on my localhost correctly. All data points obtained from my endpoint are either "'0", "", or null.
My data: [SmartConnectorErrors.PNG]
/Values from endpoint:
[ { "Name": "DCTempSwapSTPT", "Description": null, "Type": 3, "Writeable": 0, "Forceable": 0, "State": 1, "Unit": null, "Value": "0", "ParentId": "root", "Id": "DCTempSwapSTPT" }, { "Name": "FAS_ATS_Utility_Status", "Description": null, "Type": 2, "Writeable": 0, "Forceable": 0, "State": 1, "Unit": null, "Value": "", "ParentId": "root", "Id": "FAS_ATS_Utility_Status" }, { "Name": "FAS_Data_Center_Humidity", "Description": null, "Type": 3, "Writeable": 0, "Forceable": 0, "State": 1, "Unit": null, "Value": "0", "ParentId": "root", "Id": "FAS_Data_Center_Humidity" }, { "Name": "FAS_Data_Center_Temp_F", "Description": null, "Type": 3, "Writeable": 0, "Forceable": 0, "State": 1, "Unit": null, "Value": "0", "ParentId": "root", "Id": "FAS_Data_Center_Temp_F" }, { "Name": "Fuel_Level", "Description": null, "Type": 3, "Writeable": 0, "Forceable": 0, "State": 1, "Unit": null, "Value": "0", "ParentId": "root", "Id": "Fuel_Level" }, { "Name": "Gen_Alarm", "Description": null, "Type": 2, "Writeable": 0, "Forceable": 0, "State": 1, "Unit": null, "Value": "", "ParentId": "root", "Id": "Gen_Alarm" }, { "Name": "Gen_Running", "Description": null, "Type": 2, "Writeable": 0, "Forceable": 0, "State": 1, "Unit": null, "Value": "", "ParentId": "root", "Id": "Gen_Running" }, { "Name": "I2_624_01.Gen50RuntimeHr", "Description": null, "Type": 3, "Writeable": 0, "Forceable": 0, "State": 1, "Unit": null, "Value": "0", "ParentId": "root", "Id": "I2_624_01.Gen50RuntimeHr" }, { "Name": "I2_624_01.JEA_Utility_Status", "Description": null, "Type": 2, "Writeable": 0, "Forceable": 0, "State": 1, "Unit": null, "Value": "", "ParentId": "root", "Id": "I2_624_01.JEA_Utility_Status" }, { "Name": "LobbyElevAlarm", "Description": null, "Type": 2, "Writeable": 0, "Forceable": 0, "State": 1, "Unit": null, "Value": "", "ParentId": "root", "Id": "LobbyElevAlarm" }, { "Name": "LobbyLightsDemo", "Description": null, "Type": 2, "Writeable": 0, "Forceable": 0, "State": 1, "Unit": null, "Value": "", "ParentId": "root", "Id": "LobbyLightsDemo" }, { "Name": "Second", "Description": null, "Type": 3, "Writeable": 0, "Forceable": 0, "State": 1, "Unit": null, "Value": "0", "ParentId": "root", "Id": "Second" } ]
I would really appreciate any help on this matter.
Best,
Lydia
Hello Firdous,
I am currently assisting her through private messages, although right now she is attempting to troubleshoot the issue herself. This thread will be updated once the root issue is found and solved.
Hi @Nick-Iebba,
Thanks for your assistance and your feedback.
If you can share the solution at the end so other members can benefit from it, it will be cool 😀
Have a great day!
Hi @Lydia,
@Nick-Iebba helped you to solve your problem. I kindly invite you to share it with the community and click on “Accept as Solution” so other members can find the same solution through the search bar.
Thank you!
User | Count |
164 | |
34 | |
33 | |
19 | |
14 | |
11 |
