Wiser system seems not optimized for electric inertia heater
Send InviteCancel
Posted: 2026-11-0209:32 PM
I want to share my observation on my system (4x Rooms with same setup, running since >7 days), in order to understand it better and improve the confort/reliability :
Hub Gen2 - CCT501801
Heating actuator - CCTFR6700
Connected Thermostat - CCTFR6400
Powertag - R9M60
Inertia Heater (Around 1200 Watt resistor + 500 Watts Brick system - Heating in 10 min)
1st observation :
During stable phasis (like the night), relay is running into a loop of 10 min, and heating during 2 min.
--> No demand raised by the thermostat.
--> Temperature in the room is very stable, but heater is cold (No radiant heating).
Is there any way to increase this loop time to 20-30 min to use the benefit of inertia heater as well as having radiant heating ?
I saw that for some other heating system, there were possibilities of parameterizing it :
Cycles of all heaters are known by the hub, but cycles of all heaters seems synchronized together on same time, which is generating a cumulative consumption peak (Purple).
This kind of peak can exceed the energy contract and make the meter tripped.
--> Is there any mecanism to use the inertia of the heater for smoothing the consumption ?
Thanks for your post and for sharing your system behaviour.
For your first question, we recommend you to modify the night setpoint by +1°C or more to benefit on radiant heating. The connected thermostat ref CCTFR6400 you have doesn't offer to modify the cycling time, as you mention, the Renova or the Exxact devices have such functionality.
For your second question, it depends on your configuration. Wiser Home system controls heating room by room, then it is possible to set a schedule per room to avoid the energy peaks.
