Brand Logo
  • Get started
  • Get started
  • Community Home
    • By Topic
    • By Topic
      EcoStruxure Building
      • Field Devices Forum
      EcoStruxure Power & Grid
      • Gateways and Energy Servers
      APC UPS, Critical Power, Cooling and Racks
      EcoStruxure IT
      • EcoStruxure IT forum
      Remote Operations
      • Remote Operations Forum
      Industrial Automation
      • Alliance System Integrators Forum
      • AVEVA Plant SCADA Forum
      • CPG Expert Forum DACH
      • EcoStruxure Automation Expert / IEC 61499 Forum
      • Fabrika ve Makina Otomasyonu Çözümleri
      • Harmony Control Customization Forum
      • Industrial Edge Computing Forum
      • Korea Industrial Automation Forum
      • Machine Automation Forum
      • Modicon PAC Forum
      • PLC Club Indonesia
      Schneider Electric Wiser
      Power Distribution IEC
      • Eldistribution & Fastighetsautomation
      • Elektrik Tasarım Dağıtım ve Uygulama Çözümleri
      • Paneelbouw & Energie Distributie
      • Power Distribution and Digital
      • Solutions for Motor Management
      • Specifiers Club ZA Forum
      • Електропроектанти България
      Power Distribution NEMA
      • Power Monitoring and Energy Automation NAM
      Power Distribution Software
      • EcoStruxure Power Design Forum
      • LayoutFAST User Group Forum
      Light and Room Control
      • SpaceLogic C-Bus Forum
      Solutions for your Business
      • Solutions for your Business Forum
      Support
    • Geo SCADA Knowledge Base
    • Industrial Automation How-to videos
    • Digital E-books
    • Success Stories Corner
    • All Events
    • Innovation Talks
    • Innovation Summit
    • Let's Exchange Series
    • Partner Success
    • Process Automation Talks
    • Technology Partners
    • EcoStruxure Building
      • EcoStruxure Building Advisor Ideas
      Remote Operations
      • EcoStruxure Geo SCADA Expert Ideas
      • Remote Operations Devices Ideas
      • Modicon Ideas & new features
    • By Topic
    • By Topic
      • Backstage Access Resources
      Remote Operations
      • Remote Operations Blog
      • Industrie du Futur France
      • Industry 4.0 Blog
      • NEMA Power Foundations Blog
      • KNX Blog
      • Digital E-books
Wiser by Schneider Electric
  • Communities
  • Wiser by Schneider Electric
  • Subscribe to RSS Feed
Send a co-worker an invite to the Exchange portal.Just enter their email address and we’ll connect them to register. After joining, they will belong to the same company.
Alfred_SE
Lt. Commander Alfred_SE Lt. Commander
23
nischaypond
Ensign nischaypond Ensign
4
sesa96364
sesa96364 Schneider Alumni (Retired)
2
MikeP007
Crewman MikeP007
1
tearen22
tearen22
Cadet
Posted: ‎2023-02-28 06:39 AM
142
Share
Does anyone have a wiser system in their house. We're having it in our new build and have a few of the light switches attached to it at this point. Any suggestions on what else to integrate would be appreciated. Do you need a hue bridge as well to control Phillips hue lights, or can the wiser system do this without it? Sorry for the noob question... Thanks.
omegle xender
  • About Wiser
Share
Replies 4
jmckenzie
jmckenzie
Cadet
Posted: ‎2023-02-28 08:04 AM
Share
Hey there!
I personally have the Wiser in my home. I installed it after getting getting it from Home Depot. I have used it for about 3 months, I would say the biggest help is having my major appliances on it. it has been a huge help as far as learning the product and being able to work out the kinks. now granted it was a Home Depot special and isn't very integrated but as fast as energy monitoring it works well in my case.
Share
njknh
Crewman njknh
Crewman
Posted: ‎2023-03-01 05:06 AM
Share
I've been using the Drayton Wiser system for about a month with a combi boiler and iTRVs on some radiators.
I don't use the Wiser plugs because they are expensive if you dont need them to extend the range of the Wiser Zigbee mesh - I instead use TP-Link Tapo wifi smart plugs which are about a third of the price. I can control both the heating and smart plugs through the Alexa app so it doesn't particularly matter that everything cant be controlled by the wiser app.
If you are planning on using the Wiser iTRVs be aware of the inaccuracy in temperature measurement which for me is up to 4C when the radator is hot. If you have a Wiser thermostat in the same room as the radiators with iTRVs then the Wiser system takes the temperature measurements from the thermostats rather than the iTRVs which overcomes the problem, but the thermostats are quite expensive. Some people are working round the iTRV temperature error by applying offsets. I'm just using iTRVs with separate thermostats in key rooms and old mechanical TRVs in other rooms.
I'm not using using smart bulbs, but do use smart plugs to control some lamps so they can be automatically turned on/off during holidays etc. As far as I know the Philips hue lights are not compatible with the Wiser Hub, so you will probably need a separate Philips hub.
I like the fact that the Wiser system will continue to work even if the wifi or internet goes down as the schedules are stored locally rather than in the cloud. My house is old and too poorly insulated to benefit from the ECO mode, but I find the Comfort mode works reasonably well in applying weather compensation once it has learned the characteristics of your house.
Share
janim
Janeway janim Janeway
Janeway
Posted: 4 weeks ago
88
Share
Posted: 4 weeks ago
I have Wiser by SE system in Finland and it is created by Tuya. I could add any WiFi Tuya devices without extra hub.If you have exemple Nedis WiFi device and want to use it in Wiser. Put your Wiser to find IP Camera and then it could find WiFi devices.
I also add Lidl Tuya Hub to add 3rd party ZigBee devices to Wiser. I have Lidl devices and Hue lights in Lidl Hub.
My system contain now 70 devices.
If it ain't broke, don't fix it.
Share
lgo44
Lieutenant | EcoXpert Master lgo44 Lieutenant | EcoXpert Master
Posted: 2 weeks ago
In response to janim
Share
Posted: 2 weeks ago
I have a wiser system a home for one year, I'm using 12 room stats, 12 heating actuators, 6 dimmablelights and 5 shutters. This runs correctly
In addition I use also Home assistant with the Drayton Wiser Integration that can also manage all these devices, that provides many comfort.
Share
Additional options
You do not have permission to remove this product association.
You can subscribe to this forum after you log in or create your free account.
Already have an account?Login
Terms & Conditions Privacy Notice Change your Cookie Settings © 2023 Schneider Electric, Inc
