Continue
  • My Subscriptions
  • Events
Wiser Hub2 / Matter – Wiser Dimmer devices - Brightness commands does not work
  • Wiser Hub2 / Matter – Wiser Dimmer devices - Brightness commands does not work
David_SE
David_SE Mentor
214
Alfred_SE
Alfred_SE Leader
24
Maude.wiser.
Maude.wiser. Contributor
22
dannyvdpoel
dannyvdpoel
Explorer
Posted: ‎2026-11-01 05:55 AM . Last Modified: ‎2026-11-03 12:45 AM
156
Is this a known compatibility issue with dimming through the Wiser Hub2 Matter Bridge, and is a firmware or software fix available? What additional diagnostic information would help investigate it?
I am experiencing incorrect brightness control of an LK Wiser dimmer through the Wiser Hub2 Matter Bridge connected to Home Assistant.
Setup
  • Dimmer: LK FUGA Wiser wireless dimmer, model 545D6102
  • Wiser Hub 2nd Generation, model 17622, firmware 4.50.4
  • Wiser Home App 7.7.1 (Build 3)
  • Home Assistant Container 2026.10.4
  • Python Matter Server 8.1.0
  • Raspberry Pi 4, running Home Assistant and Matter Server in Docker with host networking
Expected behaviour
A light.turn_on command with, for example, brightness_pct: 60 should turn on or adjust the light to 60%.
Observed behaviour
  • Dimming directly through the Wiser Home app works. When Off and setting to 60% produces normal illumination and a stable reported value in the Wiser Home app.
  • A simple turn-on command without a brightness parameter produced Off → normal illumination (value not logged) → 1%, it takes 1-2 seconds as reported in the Wiser app.
  • Brightness commands from Home Assistant does not provide the expected behavior.  This has been observed with both brightness: 255 (100%) and brightness_pct: 60.
  • Home Assistant identifies the dimmer as supporting brightness control. When the light is set to 100% in Wiser, Home Assistant correctly reports on and brightness: 255.
Troubleshooting completed
The Matter pairing was removed and re-established without resolving the issue. Explicitly setting transition: 0 did not change the outcome.
When dimming set correctly to 60% in the Wiser Home App, Home Assistant debug logs show received brightness values of 153 (approximately 60%).
The exact outgoing Matter command has not yet been captured.
To rule out Home Assistant causing problems, I disconnected Home Assistant in the Wiser Home App and connected Apple Home directly to Wiser Hub2.
Same result: Brightness control through Apple Home produces incorrect behaviour: the light turns on shortly before turning off (1%) instead of reaching the requested brightness.
Update 3rd Nov:
Power off and on the Hub seems to have resolved the main issues for now. Still there seems to be a consistent problem to change dimmer from one value to another in one step:
Power On Behaviour is 50%.
Scenario: Going from 70% to 25% will make the dimmer: 70% -> 50% -> 25%, two step illumination clearly notable. Similar dimming up to 70%, it goes: 0% ->  50% -> 70%
How can that be avoided without using the Power On Behaviour, which is linked pressing the physical button.
  • Bugs
  • Connectivity Devices
  • Gateways and Hubs
Replies 5
dannyvdpoel
dannyvdpoel
Explorer
Posted: ‎2026-11-03 12:10 AM
145
Update 3rd Nov:
David_SE
David_SE Mentor
Mentor
Posted: ‎2026-11-04 04:44 AM
In response to dannyvdpoel
128
Hi @dannyvdpoel ,
Thanks for your post and for updating your wiser experience. Please can you send an email to our customer support at dk-ts@se.com and provide the link of that post, system details (such as MAC address, account email) to start an investigation.
If needed, you can come back here with your ticket number.
BR
David
dannyvdpoel
dannyvdpoel
Explorer
Posted: ‎2026-11-05 02:52 AM
In response to David_SE
108
@David_SE Done, here is the Schneider Electric Case # 127450645. Feel free to reach out
David_SE
David_SE Mentor
Mentor
Posted: ‎2026-11-12 04:24 AM
37
Thanks @dannyvdpoel, i saw the process on your ticket and discussed with the CC agent.
I hope your issue will be solved soon.
BR
David
dannyvdpoel
dannyvdpoel
Explorer
Posted: ‎2026-11-13 03:48 AM
Unfortunately not yet solved with the new Wiser Hub 2nd Gen firmware: 4.52.3.
