One RAD valve out of five eating up batteries
Send InviteCancel
Posted: 2026-10-2710:06 PM
Newbie here. Retired IT specialist. Selected Wiser to automate heating, system installed very recently. One valve (of two) in room where room stat is also fitted is using up batteries. No problem with mechanical fitting to valve. No problem with movement of valve itself. Suspect Zigbee signsl too weak: occasionally valve reports low signal and goes orange on display. Advice requested
Thanks for your post. I presume that you use the same batteries in all your devices, then, poor signal can be a reason, perhaps you can add a smart plug in your system between the hub and the "faulty" valve, as it can be also a Zigbee router.
Pay attention to remove the batteries of the "faulty" device, then connect the smart plug and reinsert the batteries to rebuild the zigbee network.
