Continue
  • My Subscriptions
  • Events
Gen 1 Hub and thermostat short cycling heat pump
  • Gen 1 Hub and thermostat short cycling heat pump
David_SE
David_SE Mentor
214
Alfred_SE
Alfred_SE Leader
24
Maude.wiser.
Maude.wiser. Contributor
22
StuartA
StuartA
Explorer
Posted: ‎2026-10-31 04:56 AM
121
I replaced a Danfoss wireless stat with a Wiser Gen 1 hub and wireless stat. Over the last 24 hours, the Wiser system has caused the heat pump to turn on roughly 40 times, for 10-14 minutes at a time. Only one period overnight did it remain on for about 5 hours. The hub is configured for "heat pump". Any advice please?
  • Temperature Control
David_SE
David_SE Mentor
Mentor
Posted: ‎2026-11-05 02:12 AM
93
Hi @StuartA ,
Thanks for your post.
First, please note in the Wiser Gen2 hub, we implement a logic to avoid heat pump cycling. However in Gen 1 this logic is not available but you can apply a workaround.
If, for example, you want your home to be heated at 20°C for a period of time, we suggest to select a higher set point like 22°C for most of that period and to reduce the set point to 18°C for the rest of that period.
Your heat pump being typically less powerful than your former boiler, will require a longer time to heat up your home. By scheduling the HP in that manner, it will run only one cycle for that period of time.
BR
David
David_SE
David_SE Mentor
Mentor
93
Hi @StuartA ,
BR
David
StuartA
StuartA
Explorer
Posted: ‎2026-11-05 01:56 PM
In response to David_SE
Thanks David. I have a non smart wireless thermostat and in use with the pump it's not causing much short cycling - we just keep the same temperature 24/7. I'll use this over winter and consider upgrading to the Gen2 hub if I feel that it would benefit us.
