Function request
Send InviteCancel
Posted: 2026-08-2604:44 AM. Last Modified: 2026-08-2704:45 AM
Function request
System could contain only 10 automations. This should be much higher. Now in Wiser by SE system I have 60 automations and transition to Wiser Hole is in hold.
In old system I can command from scene to activate / deactivate automation. This is needed too.
Scene should contain possibility to add delays.
Wiser by SE delays works here. Example: user can control multiple lights to start one by one.
SPOT price control accuracy is too high. All prices should be in cents not Euros. If price is in Euros then kWh need to change to MWh. Then we have enough accuracy to control by SPOT.
Wiser by SE contain cents / kWh with 2 decimal.
Still missing correct electricity measurements from plugs: CCT711119
Wiser by SE contain possibility swipe to left/right to change room view. This is also needed.
System should contain user management. Admin user and regular user.
Wiser by SE contain possibility create accounts to all users and no need to use same account to all users.
Regular user don't need permission to make system changes, but can see alerts and can control devices.
This is also cyber security issue
Automations need delay to permission.
example: Door is open more than 5 minutes then send notification to users. Now this is not possible to do.
