P3T32 - CT ratio not working properly
Protection & Control
Select a Country
  • EcoStruxure Power & Grid
  • Protection & Control
  • P3T32 - CT ratio not working properly
Araceli_Monje
Araceli_Monje Mentor
74
JuanRayo
JuanRayo Mentor
38
Arun-kumar_PS
Arun-kumar_PS Mentor
33
Back to Protection & Control
POWERGRIDS
POWERGRIDS
Explorer
Posted: ‎2025-11-15 10:18 PM
402
Dear all,
We are facing a problem, with a brand new P3T32 relay.
We set the CT ratio @2500/1 at the LV side (CT'), but when we inject 1A, with Omicron the relay measures 2000A instead of 2500A. The wiring is correct and idetntical to the HV side. HV side has a CT with ratio, 1600/1. The transformer is a 40MVA YND11, 21/11.5kV. The power flow is from the LV to the HV side (Gas turbine plant)
Please let us know if we can solve the issue, by updating the firmware of the relay...
  • Application cases
  • PowerLogic P3
Tags (2)
  • P3T32 RATIO PROBLEM
Karthik.P
Karthik.P Troubleshooter
Troubleshooter
Posted: ‎2025-11-25 01:28 AM
The HV connections and LV connections are not identical. Please refer the attachment and correct your wiring. If the issue still persists after the wiring correction, then please share the relay ordering code, wiring connection details and the relay configuration file
Karthik.P
Troubleshooter
