Hi folks,
My question is very simple, Can a Saitel HUe make logics? I mean when an AB_DI receive one signal, AB_DO send a close signal for example.
If it is possible; Are there any limits that should I take into account?
Thanks in advance
hello @asdasd
Absolutely yes. Like any other member of saitel family and T500, Logical programs can be designed/developed using Isagraf (for complicate programs) and Formula (which I recommend you for the functionality you mentioned). Here below I attach an example where in tab "command" we leave "formula" (1) device as the source of the command then we add the logical program where the points could be digital signals(2) and finally according the logical programs designed we execute the command (3) in a AB_DO. I am also attaching a document with more details about how to configure "formulas" and the functionalities supported.
