EPRW and OPRW
Protection & Control
Send InviteCancel
2025-11-0708:37 AM
EPRW and OPRW
I have a question regarding the EPRW and OPRW in ATV630.
How are these two tags calculated? Are they based on averaged models (current and voltage RMS) or based on dq transformation?
Do they always follow the same trend? For example they are both either increasing or decreasing at the same time? Or there might be cases that one is increasing while the other one is not?
Please note the offers you are referring to do not belong to Protection & Control portfolio and therefore are not managed inside this Forum, my apologies. Could you please connect with your SE representative so that he can connect you with the right people that are able to help you with your question?. Thanks for your understanding.
