EASERGY P5M30
Protection & Control
Select a Country
  • EcoStruxure Power & Grid
  • Protection & Control
  • EASERGY P5M30
Araceli_Monje
Araceli_Monje Mentor
74
JuanRayo
JuanRayo Mentor
39
Arun-kumar_PS
Arun-kumar_PS Mentor
33
Back to Protection & Control
DERBECOURT
DERBECOURT Explorer
Explorer
Posted: ‎2025-10-28 09:39 AM
526
EASERGY P5M30
Bonjour,
J'ai mis en service 2 relais P5M30 associés à des contacteurs. Dès la fermeture du contacteur, le message "Therm Rsv motor alarm" apparait. Je ne comprends pas la fonction ou le paramètre qui génère cette alarme.
Pouvez-vous me renseigner sur ce sujet?
Bien cordialement
Hervé.DERBECOURT
CSE Lille
  • PowerLogic P5
Chunmei_Yang
Chunmei_Yang Troubleshooter
Troubleshooter
Posted: ‎2025-11-13 12:12 AM
A measurement output about the remaining time to trip ("Estimated time to trip") is
provided, based on the hypothesis that the load current present remains constant
until thermal overload operation occurs.
A time remaining alarm (Therm Rsv motor alarm) will operates when the
calculated remaining time is less than or equal to the "Reserve time thermal
alarm" time setting.
Kindly check if the configuration 'Reserve time thermal alarm' is too short, or the thermal lever have reached to a high level.
Araceli_Monje
Mentor
Posted: ‎2025-11-05 03:07 AM
@Arun-kumar_PS , could you please help with this question or guide @DERBECOURT to the right person that is able to support here?, thx.
Chunmei_Yang
Troubleshooter
