84434members
353633posts
Discover how ComPacT New Generation helps enhance Power Availability in only 60 sec !
J_Travostino
Admiral Admiral
Admiral
Modern electrical installations are becoming increasingly complicated, yet power uptime is more critical than ever.
Our New Generation of ComPacT breakers are designed to maximize power availability and reliability, in three key ways:
- by ensuring optimized selectivity and coordination with upstream and downstream Schneider Electric breakers
- by providing corrective, preventive and predictive maintenance for asset management, thanks to our advanced MicroLogic trip units
- by sending alerts as well as local indication, with the new wireless auxiliary contact.
Watch this 60 seconds video to discover more. 👇
And as always, do not hesitate to post any comments or questions hereafter ...
Julien Travostino
Power Distribution & Digital forum community owner
Power Products Div.
J_Travostino
Admiral Admiral
Admiral
Re: Discover how ComPacT New Generation helps enhance Power Availability in only 60 sec !
Hello @T_Parks ,
well, as a first step, you should check out our dedicated webpage here 👈
You'll find lots of valuable information on this Power Availability topic.
Hope this helps.
Julien Travostino
Power Products Div.
4 Replies 4
J_Travostino
Admiral Admiral
Admiral
And of course find more info about this new generation of MCCB on the dedicated website by cliking on it below:
Julien Travostino
Power Products Div.
T_Parks
Lieutenant
Lieutenant
720
Hello
However, where can I find more information on how to maximize power availability?
Which electrical architectures are recommended?
Which applicative field?
T_Parks
J_Travostino
Admiral Admiral
Admiral
Hello @T_Parks ,
Hope this helps.
Julien Travostino
Power Products Div.
Gregoire_Brun
Lt. Commander Lt. Commander
hello T Parks
This new generation of breaker is quite similar for principal performences as the previous compact NSX
Added values are more about accessories and visibilities of Accessories true the front cover and a new handle more ergonomic.
And some new acc
  • OF SD screw less
  • Mn MX screw less
  • OF SD without wiring with zeegbee communication system.
