Welcome to the new Schneider Electric Community
It's your place to connect with experts and peers, get continuous support, and share knowledge.
Important Announcement: WELCOME to the new Schneider Electric Community! Community is now no longer part of Exchange, and is now rebranded under se.com. If you have any bookmarks and links saved, we request you to update them to ensure that you continue accessing our community from this new location. For any issues that you might encounter as part of this change, please reach out to SchneiderCommunity.Support@se.com, and the team will help to get your issues resolved.
Send a co-worker an invite to the Exchange portal.Just enter their email address and we’ll connect them to register. After joining, they will belong to the same company.
82212members
349805posts
How do I pick circuit breakers that will selectively coordinate?
NEMA Engineers & Designers Forum
A community for the free exchange of ideas and information related to engineers, specifiers and designers within USA and Canada or those who design with North American products.
JamieJurin
Crewman Crewman
Crewman
331
For completely selective coordination (sometimes referred to as 0.01 seconds) you will first need to know the fault current at the point(s) in the system where you need to selectively coordinate.  If you do know this value, you can start with an infinite source calculation at the source transformer which is calculated by dividing the transformer's full-load amperage by the percent impedance (%Z).  From there, you can now use the manufacturer's guide book such as Square D / Schneider Electric's Data Bulletin 0100DB0501 titled "Short Circuit Selective Coordination for Low Voltage Circuit Breakers".  Or, you might be able to find the same type of information via an on-line tool such as the one found here:  Selective Coordination Analysis (squared.com)
This on-line tool will also help you to calculate the fault currents in your system.
LouisDamico
Lieutenant Lieutenant
Lieutenant
Re: How do I pick circuit breakers that will selectively coordinate?
Thanks for the helpful information!
1 Reply 1
LouisDamico
Lieutenant
