Posted: 2024-01-28 06:55 PM
Hi All,
I have the configuration with M580 HSBY and STB Distibuted IO via the RSTP protocol but the customer asked to add the Modbus RTU/Serial Protocol.Tried to add the BMXNOM0200 but can't. What module should I use in this case? Thanks
Posted: 2024-01-28 11:31 PM
Hello Godfrey,
I think you can offer EGX150 or Panel server to be a gateway and be connected to CRA service port which will guaranty the redundant connection between the two CPUs
But please consider the following:
The speed of service port is 5 Mbps so please don`t add many gateways (my recommendation 4 or 5 gateways and each gateway handle 7 RS485 devices)
Maybe the main controller will loss the communication with RS485 devices when the system transfer between CPUs for 3 or 5 second depends on number of requests and devices , and incase the system controls in RS485 devices you will need to increase the devices watchdog or timeout a little bit.
Posted: 2024-01-28 11:52 PM
Godfrey
You can only add the BMXNOM0200 to a drop rack not the CPU racks.
The alternative assuming you require Modbus RTU RS485 protocol is to use a modbus ethernet to modbus serial gateway such as a panel server 600.
Trinxs
Hello Godfrey,
Godfrey
Trinxs
Posted: 2024-02-04 03:08 PM
Thanks guys
