Using a Summation CT for a PM5563
Metering & Power Quality
  • EcoStruxure Power & Grid
  • Re: Using a Summation CT for a PM5563
Charles_Murison
Charles_Murison Champion
571
Mehran_Mehrnia
Mehran_Mehrnia Champion
203
Ramasamy_N
Ramasamy_N Champion
115
MAPH
MAPH
Explorer
Posted: ‎2025-06-19 07:17 AM
821
I have a system that requires monitoring in its total generation. This system has two independent generation circuits of 400A each. Can summation CT be used to combine what is measured by the CTs of each system (same CT model) and then feed a PM5563?
  • PM5000
Charles_Murison
Champion
Posted: ‎2025-06-19 09:38 AM
812
Hello @MAPH
Have a look at https://www.se.com/ca/en/faqs/FA202846/, note that there are a few conditions required for a configuration of this nature to work.
Charles
Replies 3
Charles_Murison
Champion
813
Hello @MAPH
Charles
MAPH
MAPH
Explorer
Posted: ‎2025-06-19 10:56 AM
810
Thank you, Charles.
If I use two sets of CTs 400:5, do I need to configure my meter to 800:10, or what change do I need to make in my configuration? Because I am expecting up to 5 A from each CT.
Charles_Murison
Champion
Posted: ‎2025-06-19 04:49 PM
Hello @MAPH ,
The first question I was ask is what does the meter support. If meter cannot support 10A, you will need to use larger CTs. Note that CTs can often output more than 5A, be sure the combined maximum from both CTs are less that the maximum the meter can support.
The CT ratio would match the CTs used on 1 source.
Charles
