Continue
  • My Subscriptions
  • Events
Simulating sag, brownout, etc.. in the lab - How?
Metering & Power Quality
  • EcoStruxure Power & Grid
  • Simulating sag, brownout, etc.. in the lab - How?
Charles_Murison
Charles_Murison Champion
582
Mehran_Mehrnia
Mehran_Mehrnia Champion
217
Ramasamy_N
Ramasamy_N Champion
117
ron_kent
ron_kent
Explorer
Posted: ‎2026-10-26 10:17 AM
277
We have a few PM8240 and ION9000 meters which are fantastic. We need to do some testing in our lab of simulating various power conditions like sag, brownout, etc.. with these meters. Is there a standard recommendation for this, or an inexpensive way outside of a full-size grid simulator that can do this?
  • ION9000
  • PM8000
  • Power Quality
Charles_Murison
Champion
Posted: ‎2026-10-27 09:32 AM
Hello @ron_kent ,
A lot depends on what kinds of tests you need to perform. For example if you need precise timing with specific voltage measurements compared to general meter behavior. If precise timing is required or very specific voltage measurements you would like need to look into equipment to give you those signals. If however you are looking for general meter behavior you could possibly look at using devices like a variac (variable autotransformer).
Anything used will need to be electrically safe and in compliance with local electrical codes.
Charles
Replies 5
Mehran_Mehrnia
Champion
Posted: ‎2026-10-27 08:25 AM
Hi @ron_kent
The preferred method is to use a secondary-injection test set or programmable AC source to apply actual voltage signals to the meter. For example, if the Sag/Swell thresholds are configured at 90% and 110% of nominal voltage, the applied voltage can be reduced below 90% to simulate a sag or increased above 110% to simulate a swell.
Another possible method for demonstration purposes is to use the meter's Demo mode (Volts Mode as DEMO) and adjust the Nominal Voltage or PT ratio so that the simulated voltage falls outside the configured Sag/Swell thresholds.
However, this method is not recommended for validating actual meter behavior because not all meter modules and functions operate in Demo mode as they do with real voltage/current inputs.
Therefore, for meaningful laboratory testing of the PM8240 or ION9000, applying real signals using a secondary-injection test set, such as an OMICRON CMC or equivalent programmable source, would be the preferred approach.
Best Regards,
-Mehran
L3 Expert Advanced metering
Charles_Murison
Champion
Hello @ron_kent ,
Charles
CEFISE
CEFISE
Explorer
Posted: ‎2026-10-28 10:09 AM
Hello Ron,
Event recording tests (sags/swells) can be conducted in a laboratory setting using Omicron test equipment that includes power quality (PQ) testing functionality.
As an additional recommendation, I suggest you consult the IEC 62586 standard, which establishes the requirements for power quality testing.
Best regards,
Gerardo Robledo
Charles_Murison
Champion
Posted: ‎2026-11-04 07:56 AM
163
Hello @ron_kent ,
Did you still need any help on this topic?
Charles
ron_kent
ron_kent
Explorer
Posted: ‎2026-11-04 08:41 PM
These were all super helpful responses! I've been using the meters demo mode but didn't realize that there were some adjustable parameters. The Schneider team really thought of everything with these devices.
