Question about importing configuration files (.cfg) to HDPM6000 head unit
Metering & Power Quality
Select a Country
  • EcoStruxure Power & Grid
  • Question about importing configuration files (.cfg) to HDPM6000 head unit
Charles_Murison
Charles_Murison Champion
571
Mehran_Mehrnia
Mehran_Mehrnia Champion
203
Ramasamy_N
Ramasamy_N Champion
115
T.Okada
T.Okada
Contributor
Posted: ‎2026-07-29 06:24 PM
131
I have a question about importing configuration files (.cfg) to the HDPM6000 head unit.
The HDPM6000 user guide states: “Only upload configuration files to HDPM head units with the same firmware version.”
In this context, do I also need to consider the firmware version of the branch units, or only that of the head unit?
Okada
  • HDPM6000
Mehran_Mehrnia
Champion
Posted: ‎2026-07-30 08:09 AM
1
118
Hi @T.Okada
The configuration file is uploaded directly to the head unit, but firmware compatibility should always be evaluated at the entire system level, not just the head unit alone.
As noted in the HDPM6000 Installation Guide, all system components including the Head Unit System, 3-Phase Meter, Branch Modules, I/O Modules, and EIM Modules should run on the same firmware bundle version to avoid unexpected behavior. Therefore, the safest approach is to ensure that both the source and target HDPM6000 systems use the same bundle version across all connected components, including the branch modules.
As discussed in previous HDPM6000 1-to-1 migrations forum, if a configuration is uploaded to a system running a different firmware version, the upload may still succeed, but all critical settings should be manually verified afterward.
Best Regards,
-Mehran
L3 Expert Advanced metering
Mehran_Mehrnia
Champion
1
119
Hi @T.Okada
Best Regards,
-Mehran
T.Okada
T.Okada
Contributor
Posted: ‎2026-07-31 01:43 AM
Hi @Mehran_Mehrnia,
Thank you for your reply.
As you suggested, I will check the system-wide firmware version of the HDPM6000.
Best regards,
Okada
